[Proj] Compiling on Solaris 10 x86
Vinicius Carvalho vinicius.carvalho at ericsson.com
Wed Mar 23 04:57:40 PDT 2011
Hi There! I'm trying to compile and install this library on a Solaris 10 x86 server. Needed for the PostGIS install.
So, I ran ./configure and everything went ok, but gmake is throwing an error:
Making all in src
make[1]: Entering directory `/tmp/proj-4.7.0/src'
make  all-am
make[2]: Entering directory `/tmp/proj-4.7.0/src'
/bin/bash ../libtool --tag=CC   --mode=link gcc  -g -O2 -no-undefined -version-info 6:6:6  -o libproj.la -rpath /usr/local/lib PJ_aeqd.lo PJ_gnom.lo PJ_laea.lo PJ_mod_ster.lo PJ_nsper.lo PJ_nzmg.lo PJ_ortho.lo PJ_stere.lo PJ_sterea.lo PJ_aea.lo PJ_bipc.lo PJ_bonne.lo PJ_eqdc.lo PJ_imw_p.lo PJ_krovak.lo PJ_lcc.lo PJ_poly.lo PJ_rpoly.lo PJ_sconics.lo proj_rouss.lo PJ_cass.lo PJ_cc.lo PJ_cea.lo PJ_eqc.lo PJ_gall.lo PJ_labrd.lo PJ_lsat.lo PJ_merc.lo PJ_mill.lo PJ_ocea.lo PJ_omerc.lo PJ_somerc.lo PJ_tcc.lo PJ_tcea.lo PJ_tmerc.lo PJ_airy.lo PJ_aitoff.lo PJ_august.lo PJ_bacon.lo PJ_chamb.lo PJ_hammer.lo PJ_lagrng.lo PJ_larr.lo PJ_lask.lo PJ_nocol.lo PJ_ob_tran.lo PJ_oea.lo PJ_tpeqd.lo PJ_vandg.lo PJ_vandg2.lo PJ_vandg4.lo PJ_wag7.lo PJ_lcca.lo PJ_geos.lo PJ_boggs.lo PJ_collg.lo PJ_crast.lo PJ_denoy.lo PJ_eck1.lo PJ_eck2.lo PJ_eck3.lo PJ_eck4.lo PJ_eck5.lo PJ_fahey.lo PJ_fouc_s.lo PJ_gins8.lo PJ_gstmerc.lo PJ_gn_sinu.lo PJ_goode.lo PJ_hatano.lo PJ_loxim.lo PJ_mbt_fps.lo PJ_mbtfpp.lo PJ_mbtfpq.lo PJ_moll.lo PJ_nell.lo PJ_nell_h.lo PJ_putp2.lo PJ_putp3.lo PJ_putp4p.lo PJ_putp5.lo PJ_putp6.lo PJ_robin.lo PJ_sts.lo PJ_urm5.lo PJ_urmfps.lo PJ_wag2.lo PJ_wag3.lo PJ_wink1.lo PJ_wink2.lo pj_latlong.lo pj_geocent.lo aasincos.lo adjlon.lo bch2bps.lo bchgen.lo biveval.lo dmstor.lo mk_cheby.lo pj_auth.lo pj_deriv.lo pj_ell_set.lo pj_ellps.lo pj_errno.lo pj_factors.lo pj_fwd.lo pj_init.lo pj_inv.lo pj_list.lo pj_malloc.lo pj_mlfn.lo pj_msfn.lo proj_mdist.lo pj_open_lib.lo pj_param.lo pj_phi2.lo pj_pr_list.lo pj_qsfn.lo pj_strerrno.lo pj_tsfn.lo pj_units.lo pj_zpoly1.lo rtodms.lo vector1.lo pj_release.lo pj_gauss.lo nad_cvt.lo nad_init.lo nad_intr.lo emess.lo pj_apply_gridshift.lo pj_datums.lo pj_datum_set.lo pj_transform.lo geocent.lo pj_utils.lo pj_gridinfo.lo pj_gridlist.lo jniproj.lo pj_mutex.lo pj_initcache.lo  -lm
rm -fr  .libs/libproj.so .libs/libproj.so.0 .libs/libproj.so.0.6.6
gcc -shared -Wl,-h -Wl,libproj.so.0 -o .libs/libproj.so.0.6.6  .libs/PJ_aeqd.o .libs/PJ_gnom.o .libs/PJ_laea.o .libs/PJ_mod_ster.o .libs/PJ_nsper.o .libs/PJ_nzmg.o .libs/PJ_ortho.o .libs/PJ_stere.o .libs/PJ_sterea.o .libs/PJ_aea.o .libs/PJ_bipc.o .libs/PJ_bonne.o .libs/PJ_eqdc.o .libs/PJ_imw_p.o .libs/PJ_krovak.o .libs/PJ_lcc.o .libs/PJ_poly.o .libs/PJ_rpoly.o .libs/PJ_sconics.o .libs/proj_rouss.o .libs/PJ_cass.o .libs/PJ_cc.o .libs/PJ_cea.o .libs/PJ_eqc.o .libs/PJ_gall.o .libs/PJ_labrd.o .libs/PJ_lsat.o .libs/PJ_merc.o .libs/PJ_mill.o .libs/PJ_ocea.o .libs/PJ_omerc.o .libs/PJ_somerc.o .libs/PJ_tcc.o .libs/PJ_tcea.o .libs/PJ_tmerc.o .libs/PJ_airy.o .libs/PJ_aitoff.o .libs/PJ_august.o .libs/PJ_bacon.o .libs/PJ_chamb.o .libs/PJ_hammer.o .libs/PJ_lagrng.o .libs/PJ_larr.o .libs/PJ_lask.o .libs/PJ_nocol.o .libs/PJ_ob_tran.o .libs/PJ_oea.o .libs/PJ_tpeqd.o .libs/PJ_vandg.o .libs/PJ_vandg2.o .libs/PJ_vandg4.o .libs/PJ_wag7.o .libs/PJ_lcca.o .libs/PJ_geos.o .libs/PJ_boggs.o .libs/PJ_collg.o .libs/PJ_crast.o .libs/PJ_denoy.o .libs/PJ_eck1.o .libs/PJ_eck2.o .libs/PJ_eck3.o .libs/PJ_eck4.o .libs/PJ_eck5.o .libs/PJ_fahey.o .libs/PJ_fouc_s.o .libs/PJ_gins8.o .libs/PJ_gstmerc.o .libs/PJ_gn_sinu.o .libs/PJ_goode.o .libs/PJ_hatano.o .libs/PJ_loxim.o .libs/PJ_mbt_fps.o .libs/PJ_mbtfpp.o .libs/PJ_mbtfpq.o .libs/PJ_moll.o .libs/PJ_nell.o .libs/PJ_nell_h.o .libs/PJ_putp2.o .libs/PJ_putp3.o .libs/PJ_putp4p.o .libs/PJ_putp5.o .libs/PJ_putp6.o .libs/PJ_robin.o .libs/PJ_sts.o .libs/PJ_urm5.o .libs/PJ_urmfps.o .libs/PJ_wag2.o .libs/PJ_wag3.o .libs/PJ_wink1.o .libs/PJ_wink2.o .libs/pj_latlong.o .libs/pj_geocent.o .libs/aasincos.o .libs/adjlon.o .libs/bch2bps.o .libs/bchgen.o .libs/biveval.o .libs/dmstor.o .libs/mk_cheby.o .libs/pj_auth.o .libs/pj_deriv.o .libs/pj_ell_set.o .libs/pj_ellps.o .libs/pj_errno.o .libs/pj_factors.o .libs/pj_fwd.o .libs/pj_init.o .libs/pj_inv.o .libs/pj_list.o .libs/pj_malloc.o .libs/pj_mlfn.o .libs/pj_msfn.o .libs/proj_mdist.o .libs/pj_open_lib.o .libs/pj_param.o .libs/pj_phi2.o .libs/pj_pr_list.o .libs/pj_qsfn.o .libs/pj_strerrno.o .libs/pj_tsfn.o .libs/pj_units.o .libs/pj_zpoly1.o .libs/rtodms.o .libs/vector1.o .libs/pj_release.o .libs/pj_gauss.o .libs/nad_cvt.o .libs/nad_init.o .libs/nad_intr.o .libs/emess.o .libs/pj_apply_gridshift.o .libs/pj_datums.o .libs/pj_datum_set.o .libs/pj_transform.o .libs/geocent.o .libs/pj_utils.o .libs/pj_gridinfo.o .libs/pj_gridlist.o .libs/jniproj.o .libs/pj_mutex.o .libs/pj_initcache.o  -lm -lc
(cd .libs && rm -f libproj.so.0 && ln -s libproj.so.0.6.6 libproj.so.0)
(cd .libs && rm -f libproj.so && ln -s libproj.so.0.6.6 libproj.so)
false cru .libs/libproj.a  PJ_aeqd.o PJ_gnom.o PJ_laea.o PJ_mod_ster.o PJ_nsper.o PJ_nzmg.o PJ_ortho.o PJ_stere.o PJ_sterea.o PJ_aea.o PJ_bipc.o PJ_bonne.o PJ_eqdc.o PJ_imw_p.o PJ_krovak.o PJ_lcc.o PJ_poly.o PJ_rpoly.o PJ_sconics.o proj_rouss.o PJ_cass.o PJ_cc.o PJ_cea.o PJ_eqc.o PJ_gall.o PJ_labrd.o PJ_lsat.o PJ_merc.o PJ_mill.o PJ_ocea.o PJ_omerc.o PJ_somerc.o PJ_tcc.o PJ_tcea.o PJ_tmerc.o PJ_airy.o PJ_aitoff.o PJ_august.o PJ_bacon.o PJ_chamb.o PJ_hammer.o PJ_lagrng.o PJ_larr.o PJ_lask.o PJ_nocol.o PJ_ob_tran.o PJ_oea.o PJ_tpeqd.o PJ_vandg.o PJ_vandg2.o PJ_vandg4.o PJ_wag7.o PJ_lcca.o PJ_geos.o PJ_boggs.o PJ_collg.o PJ_crast.o PJ_denoy.o PJ_eck1.o PJ_eck2.o PJ_eck3.o PJ_eck4.o PJ_eck5.o PJ_fahey.o PJ_fouc_s.o PJ_gins8.o PJ_gstmerc.o PJ_gn_sinu.o PJ_goode.o PJ_hatano.o PJ_loxim.o PJ_mbt_fps.o PJ_mbtfpp.o PJ_mbtfpq.o PJ_moll.o PJ_nell.o PJ_nell_h.o PJ_putp2.o PJ_putp3.o PJ_putp4p.o PJ_putp5.o PJ_putp6.o PJ_robin.o PJ_sts.o PJ_urm5.o PJ_urmfps.o PJ_wag2.o PJ_wag3.o PJ_wink1.o PJ_wink2.o pj_latlong.o pj_geocent.o aasincos.o adjlon.o bch2bps.o bchgen.o biveval.o dmstor.o mk_cheby.o pj_auth.o pj_deriv.o pj_ell_set.o pj_ellps.o pj_errno.o pj_factors.o pj_fwd.o pj_init.o pj_inv.o pj_list.o pj_malloc.o pj_mlfn.o pj_msfn.o proj_mdist.o pj_open_lib.o pj_param.o pj_phi2.o pj_pr_list.o pj_qsfn.o pj_strerrno.o pj_tsfn.o pj_units.o pj_zpoly1.o rtodms.o vector1.o pj_release.o pj_gauss.o nad_cvt.o nad_init.o nad_intr.o emess.o pj_apply_gridshift.o pj_datums.o pj_datum_set.o pj_transform.o geocent.o pj_utils.o pj_gridinfo.o pj_gridlist.o jniproj.o pj_mutex.o pj_initcache.o
make[2]: *** [libproj.la] Error 1
make[2]: Leaving directory `/tmp/proj-4.7.0/src'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/tmp/proj-4.7.0/src'
gmake: *** [all-recursive] Error 1
Any ideas on how can I build it?
PS: I'm pretty new to solaris, I'm used with linux environments, but that's my first compilation on solaris boxes.
Regards
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110323/a7473f34/attachment.html>
