[Proj] Compiling on Solaris 10 x86
    Vinicius Carvalho
    vinicius.carvalho at ericsson.com
    Wed Mar 23 07:12:08 PDT 2011
Thanks a million Frank. That did trick. I found that ar is actually located at /usr/xpg4/bin (Have no idea what that dir is though :P)
Regards
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: 23 March 2011 14:05
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Compiling on Solaris 10 x86
On 11-03-23 07:57 AM, Vinicius Carvalho wrote:
> Hi There! I'm trying to compile and install this library on a Solaris
> 10 x86 server. Needed for the PostGIS install.
> So, I ran ./configure and everything went ok, but gmake is throwing an error:
> (cd .libs && rm -f libproj.so.0 && ln -s libproj.so.0.6.6
> libproj.so.0) (cd .libs && rm -f libproj.so && ln -s libproj.so.0.6.6
> libproj.so) false cru .libs/libproj.a PJ_aeqd.o PJ_gnom.o PJ_laea.o
> PJ_mod_ster.o PJ_nsper.o PJ_nzmg.o PJ_ortho.o PJ_stere.o PJ_sterea.o
> PJ_aea.o PJ_bipc.o
Vinicius,
I'm not sure why it is happening, but it seems that configure selected "false"
as the "ar" command on your system.  It looks like predefining the AR environment variable may operate as a clue to configure about what archive command to use.  Try:
export AR=/bin/ar
./configure
and check what "ac_ct_AR" is set to in src/Makefile.
It might also be a problem with libtool since I presume libtool is actually intercepting in the ar command.
Good luck,
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
