[Proj] New Zealand Map grid projection
Sun Mar 27 18:25:29 PDT 2011
On 11-03-27 08:26 PM, Claire Castellazzi wrote:
> Hi,
> I've got a problem with the results of the NZMG projection.
> Using proj 4.7.1 (23 sept 2009), I got :
>  >proj -I +proj=nzmg
> #2864916.8 6160570.9
> #177d8'19.853"E39d41'14.816"S
> But when I check my results with the Land Information New Zealand (LINZ)
> /_http://www.linz.govt.nz/geodetic/conversion-coordinates/online-conversion-service/converter/index.aspx_/
> I got :
> # New Zealand Map Grid Northing Easting : 6160570.9 2864916.8
> # World Geodetic System 1984 Latitude Longitude : 39 41 08.483 S 177 08 20.625 E
Claire,
Above you did not specify a datum for your NZMG projection and by default
the proj command is not changing datum.  What you want, apparently is:
cs2cs +proj=nzmg +datum=nzgd49 +to +proj=latlong +datum=WGS84
2864916.8 6160570.9
177d8'20.573"E	39d41'8.543"S 18.928
Things are still off by a fraction of a second, but much closer than you
were getting.  Note that the internal definition of +datum=nzgd49 is
   +ellps=intl +towgs84=59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993
I don't know what definition LINZ uses for NZGD49 - perhaps something
more accurate or even a grid shift based file?
Best regards,
