[Proj] Offset when converting coordinates from ESRI:31700 to EPSG:4326
Adrian Popa
adrian_gh.popa at romtelecom.ro
Mon May 2 01:03:19 PDT 2011
Hello everyone,
First of all - thank you all for the information provided (and sorry I
didn't reply sooner).
Second of all - I still must be doing something wrong - the coordinates
I get are the same in all cases (the same as EPSG 4326):
adrianp at frost:~$ echo 587486.770 326878.452 | cs2cs +init=esri:31700 +to
+init=epsg:4326 -f '%0.6f'
26.099032 44.436575 0.000000
+towgs84=28,-121,-77 -f '%0.6f'
+towgs84=44.107,-116.150,-54.648 -f '%0.6f'
+towgs84=-5.20,-126.75,-97.08,0.3160,0.4470,0.1340,0.99999 -f '%0.6f'
+towgs84=2.329,-147.042,-92.08,-0.309,0.325,0.497,5.69 -f '%0.6f'
I'm sorry, but I'm a complete noob to proj and I do not understand the
full theory behind projections, datums and all the rest - so I hope my
questions are not too irritating :)
So - any clue to what I'm doing wrong?
Thank you,
Adrian
Acest mesaj si orice fisiere sau documente atasate contin informatii confidentiale, clasificate conform regulilor interne ROMTELECOM. Mesajul este destinat doar persoanei sau entitatii adresate si altora autorizati sa-l primeasca. Daca dvs. nu sunteti in aceasta situatie, prin aceasta va informam ca orice dezvaluire, copiere, distribuire sau orice alta actiune bazata pe continutul acestor informatii este strict interzisa si pot fi aplicate sanctiuni, potrivit legii. Daca ati primit acest mesaj din greseala, va rugam sa ne informati imediat si sa stergeti mesajul din sistemul dvs. De asemenea, va rugam sa tineti cont ca transmisia nu poate fi garantata ca fiind sigura sau fara erori. Va multumim!
More information about the Proj
