[Proj] Dutch correction grid
Tue May 3 07:25:46 PDT 2011
On 11-05-03 09:34 AM, Jan Hartmann wrote:
> OK, now I get the following error (gdal svn 1.9dev, released 2011/01/18)
> $ gdal_translate -of NTv2 -ot Float32 dxy.tif dxy.gsb
> Input file size is 400, 400
> 0ERROR 1: Input and output dataset sizes or band counts do not
> match in GDALDatasetCopyWholeRaster()
> I had a quick look at the source (gdal/frmts/raw/ntv2dataset.cpp), but perhaps
> someone could point out the error, or where I should look.
Jan,
I just tried and ran into the same thing.  It is because NTv2 format also
has two error range bands.  Try creating a four band find with the last two
bands all zeros.
Best regards,
