[Proj] Offset when converting coordinates from ESRI:31700 to EPSG:4326
Mikael Rittri Mikael.Rittri at carmenta.com
Thu May 5 03:22:19 PDT 2011
Adrian wrote:
> There is a slight difference between the ESRI and EPSG projections
> (as depicted in the images attached), but I'm not sure which is
> closer to the truth ( I suspect the ESRI projection - but my data
> is not that accurate, so I could be wrong).
I should have given a source for my claim that sterea is better
than stere. Please see the archived mail from Oscar van Vlijmen:
http://lists.maptools.org/pipermail/proj/2009-April/004603.html
Best regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-----Original Message-----
From: Adrian Popa [mailto:adrian_gh.popa at romtelecom.ro]
Sent: den 2 maj 2011 14:25
To: Mikael Rittri
Cc: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Offset when converting coordinates from ESRI:31700 to EPSG:4326
Thank you Mikael, Jean-Claude
By running your command I got the coordinates I expected - thank you very much! (I thought +towgs84 parameter implied using +to +init=epsg:4326)
There is a slight difference between the ESRI and EPSG projections (as depicted in the images attached), but I'm not sure which is closer to the truth ( I suspect the ESRI projection - but my data is not that accurate, so I could be wrong).
Thank you again for your help!
Regards,
Adrian
Acest mesaj si orice fisiere sau documente atasate contin informatii confidentiale, clasificate conform regulilor interne ROMTELECOM. Mesajul este destinat doar persoanei sau entitatii adresate si altora autorizati sa-l primeasca. Daca dvs. nu sunteti in aceasta situatie, prin aceasta va informam ca orice dezvaluire, copiere, distribuire sau orice alta actiune bazata pe continutul acestor informatii este strict interzisa si pot fi aplicate sanctiuni, potrivit legii. Daca ati primit acest mesaj din greseala, va rugam sa ne informati imediat si sa stergeti mesajul din sistemul dvs. De asemenea, va rugam sa tineti cont ca transmisia nu poate fi garantata ca fiind sigura sau fara erori. Va multumim!
