[Proj] Using a GDAL-generated NTV2-file
Tue May 24 06:18:57 PDT 2011
On 11-05-24 05:51 AM, Jan Hartmann wrote:
> On 05/21/11 18:06, Frank Warmerdam wrote:
>> Jan,
>> I believe the problem is that the test.tif is south up. The NTv2 reader
>> in PROJ determines the size based on the extents and pixel size and gets
>> mixed up as the extents are upside down. You can flip test.tif with
>> gdalwarp.
>> eg.
>> gdalwarp test.tif northup.tif
> Yes, now it works. Just to be sure: is the result of the flipping correct? The
> tif file was created from two point lists, each with a lat-lon coordinate and
> the displacement in arcseconds. Gdal_grid converted the lists into two grid
> files, with the upper boundary having a smaller latitude than the lower
> coordinate. That's OK, as latitude values decrease when going north, in
> contrast with projected coordinates.
Jan,
Ah, it's gdal_grid generated.  I had assumed it's habit of producing
south-up files would have been corrected by now.  It isn't a program
I've had any real input on.
I must contest your statement that "as latitude values decrease when
going north".
> Now, what happens when I use gdalwarp on this file? Is the complete file
> mirrored? Are the displacements at the right geographical location?
gdalwarp does a rectification to north up.  In a regular case like this
it should just amount to a mirroring but you might want to inspect it a
bit to be sure the corners are still the same, etc.
The proof will be in the pudding - if you get the right transformation.
Best regards,
