[Proj] wgs84 northings and eastings
Roger Oberholtzer
roger at opq.se
Thu May 26 07:58:22 PDT 2011
On Thu, 2011-05-26 at 13:27 +0000, Mikael Rittri wrote:
> You write "transverse mercator", but it seems you mean
> ordinary mercator (Web Mercator, to be specific).
My mistake. I was doing other work at the same time with transverse
mercator. Parallel work is not always a good thing.
> So, you have to use a trick: use
> +nadgrids=@null
I remember the discussion a while back. Would I then remove the
+towgs84=0,0,0,0,0,0,0 as well? Or do I need both?
> instead. See
> http://trac.osgeo.org/proj/wiki/FAQ#ChangingEllipsoidWhycantIconvertfromWGS84toGoogleEarthVirtualGlobeMercator
Following that link eventually led me to:
http://spatialreference.org/ref/epsg/3395/
which it calls World Mercator. The definition is:
+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
Since my source data is defined as:
+proj=latlong +datum=WGS84
perhaps this more suited to my original goal?
Yours sincerely,
Roger Oberholtzer
OPQ Systems / Ramböll RST
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
roger.oberholtzer at ramboll.se
________________________________________
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
www.rambollrst.se
More information about the Proj
