[Proj] load arcSDE raw data from database and convert to lat/long
Clifford J Mugnier cjmce at lsu.edu
Wed Nov 9 07:50:16 PST 2011
Vincenzo,
Since you did not mention where you are, I had to look up the coordinates to give you a clue.  Since your coordinates are near Rome, the local coordinate system is a Gauss-Boaga Transverse Mercator referenced to the Monte Mario Datum of 1940 on the International ellipsoid.  For further details, see my column on the Italian Republic in the August 2005 issue of Photogrammetric Engineering & Remote Sensing.  The pdf of that column may be downloaded from the society's website at www.ASPRS.org.
Clifford J. Mugnier, C.P., C.M.S.
Chief of Geodesy,
Center for GeoInformatics
Department of Civil Engineering
Patrick F. Taylor Hall 3531
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA  70803
Voice and Facsimile:  (225) 578-8536 [Academic]
Voice and Facsimile:  (225) 578-4578 [Research]
Cell: (225) 328-8975 [Academic & Research]
Honorary Life Member of the
Louisiana Society of Professional Surveyors
Fellow Emeritus of the ASPRS
Member of the Americas Petroleum Survey Group
From: proj-bounces at lists.maptools.org on behalf of Vincenzo Ampolo
Sent: Wed 09-Nov-11 09:36
To: proj at lists.maptools.org
Subject: [Proj] load arcSDE raw data from database and convert to lat/long
Hi all,
I'm new to proj.
I just have a set of X, Y coordinates. i dunno what they are or the
format they use. I suppose they are a raw export of arcgis point data
exported via csv from a database. I think that arcsde is used as a
gateway. Coordinates are:
X = 1550428 Y = 2447336 and should be a point closer to lat = 41,8905198
lng = 12,4942486
X = 2159820 Y = 1457635 and should be a point closer to lat = 45,463681
lng = 9,1881714
I need a way to convert them. i tried to decode them as UTM or
cartesians point in meters but it doesn't work.
Does anyone have a suggestion in how to solve this problem?
Thanks.
Vincenzo Ampolo
http://vincenzo-ampolo.net <http://vincenzo-ampolo.net/>
http://goshawknest.wordpress.com <http://goshawknest.wordpress.com/>
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111109/decf8ed6/attachment.html>
