[Proj] load arcSDE raw data from database and convert to lat/long
Vincenzo Ampolo vincenzo.ampolo at gmail.com
Fri Nov 11 01:54:04 PST 2011
On 11/09/2011 06:32 PM, JAG wrote:
> Hi
> There is something wrong with those coordinates. The second point has larger X but smaller longitude and smaller Y but larger latitude. Are X and Y changed in one of the points?
> Regards
> José Gonçalves
No, i double checked and the points seem fine. They are stored in the
cvs file as X and Y as stated.
I just received a leak that they could be data gathered from navteq
software. Can it help?
Since all data is in a 20km^2 region i'm also thinking to detect a point
in lat/long, detect the same point in the unknow data X/Y and then write
a formula which does the conversion. It will not work worldwide but it
can work in that region. Do you think that it's feasible?
Vincenzo Ampolo
http://vincenzo-ampolo.net
http://goshawknest.wordpress.com
