[Proj] load arcSDE raw data from database and convert to lat/long
Mikael Rittri Mikael.Rittri at carmenta.com
Fri Nov 11 11:41:36 PST 2011
Perhaps the two datasets use different coordinate reference systems?
Regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
11 nov 2011 kl. 15:25 skrev "Jose Gonçalves" <jagoncal at gmail.com<mailto:jagoncal at gmail.com>>:
You should first look carefully at you data. In your first e-mail you said one of the points was:
"X = 1550428 Y = 2447336 and should be a point closer to lat = 41,8905198 lng = 12,4942486"
The geographic coordinates correspond in fact to a point in Rome. But now you give X,Y coordinates like
2447857 1069853
If coordinates are meters, this point is very far from Rome, even if you change the order in one of the points!...
Regards
José
2011/11/11 Vincenzo Ampolo <<mailto:vincenzo.ampolo at gmail.com>vincenzo.ampolo at gmail.com<mailto:vincenzo.ampolo at gmail.com>>
On 11/11/2011 11:28 AM, JAG wrote:
Looking only to the geographic coordinates, the differences are 3.6 deg in latitude and 3.3 deg in longitude. That is approximately 400 km in latitude and 270 km in longitude, which does not agree with the area you refer.
Regards
José
Sorry, i didn't mean that the two points are close together. They are from different datasets.
I've 40.000 points which are all close to
lat = 41,8905198
lng = 12,4942486
Which is Rome (italy)
And other 40.000 points which are all close to
lat = 45,463681
lng = 9,1881714
which is Milan (Italy)
This is some data i've for the first set of points (around Rome)
GeoX (M)        GeoY (N)        Colonna comune (B)      Colonna indirizzo (D)
2447857 1069853 ROMA    CIRCONVALLAZIONE GIANICOLENSE
2447336 1075588 ROMA    CIRCONVALLAZIONE CLODIA
2451643 1077238 ROMA    VIALE SOMALIA
2457129 1068315 ROMA    CIRCONVALLAZIONE TUSCOLANA
2448230 1077592 ROMA    CORSO DI FRANCIA
2448560 1069650 ROMA    PIAZZA DELLA RADIO
2456036 1078472 ROMA    VIA DIEGO FABBRI
2446575 1067372 ROMA    VIALE ISACCO NEWTON
2448850 1072702 ROMA    CORSO VITTORIO EMANUELE II
2451492 1068723 ROMA    LARGO BENEDETTO BOMPIANI
2454671 1080064 ROMA    VIA FRANCO SIMONGINI
2447642 1078350 ROMA    VIA DI VIGNA STELLUTI
2450834 1067730 ROMA    PIAZZALE DEL CARAVAGGIO
2447187 1074983 ROMA    PIAZZALE CLODIO
2446665 1073922 ROMA    PIAZZALE DEGLI EROI
2448836 1074408 ROMA    PIAZZALE FLAMINIO
2447369 1075612 ROMA    PIAZZALE MARESCIALLO GIARDINO
2448234 1076254 ROMA    PIAZZA APOLLODORO
2452382 1080020 ROMA    PIAZZA DELL'ATENEO SALESIANO
2448494 1073731 ROMA    PIAZZA CAVOUR
2456566 1070962 ROMA    PIAZZA DELLE CAMELIE
2451500 1076660 ROMA    PIAZZA DI PRISCILLA
2447346 1076534 ROMA    PIAZZA LAURO DE BOSIS
2447584 1076916 ROMA    PIAZZALE MARESCIALLO DIAZ
2448307 1075184 ROMA    PIAZZA MONTE GRAPPA
2445891 1072333 ROMA    PIAZZA PIO XI
2447714 1078540 ROMA    PIAZZA STEFANO JACINI
Thanks for all.
Vincenzo Ampolo
<http://vincenzo-ampolo.net>http://vincenzo-ampolo.net
<http://goshawknest.wordpress.com>http://goshawknest.wordpress.com
Proj mailing list
<mailto:Proj at lists.maptools.org>Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
<http://lists.maptools.org/mailman/listinfo/proj>http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111111/c0d9e794/attachment.html>
