[Proj] Using jniwrap
    Martin Desruisseaux
    martin.desruisseaux at geomatys.fr
    Tue Nov 22 18:13:32 PST 2011
Hello Michael
I just tried on my side and it worked well. Did you compiled with "make", and
executed "make install" after a successful Proj.4 build? I believe (but I'm not
sure, Frank could confirm) that "make install" is necessary in order to copy
some necessary files like the EPSG list of definitions in proper locations.
Maybe the exception that you get is caused by Proj.4 not finding the EPSG file?
     Martin
Le 23/11/11 02:57, Michael Speth a écrit :
> Anyone have experience with using the jniwrap java wrapper?
> I've compiled the jar and set the native library path; however, I get an error
> when I try to run the example from the README.  Is there something that I
> haven't configured correctly?
> [code]
>         PJ sourcePJ = new PJ("+init=epsg:32632");           // (x,y) axis order
>         PJ targetPJ = new PJ("+proj=latlong +datum=WGS84"); // (?,?) axis order
>         double[] coordinates = {
>             500000,       0,   // First coordinate
>             400000,  100000,   // Second coordinate
>             600000, -100000    // Third coordinate
>         sourcePJ.transform(targetPJ, 2, coordinates, 0, 3);
>         System.out.println(Arrays.toString(coordinates));
> [output]
> Exception in thread "main" java.lang.IllegalArgumentException: +init=epsg:32632
>     at org.proj4.PJ.<init>(Unknown Source)
>     at org.landcare.scenzgrid.proj4.test.HEALPixTest.main(HEALPixTest.java:36)
> Thanks
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111123/9305a70f/attachment.html>
More information about the Proj
