[Proj] Using jniwrap
    Michael Speth
    spethm at landcareresearch.co.nz
    Wed Nov 23 12:38:23 PST 2011
I was able to use the jar without issue after compiling with make
install (had to do a make clean first).  My next question is how do I
use the tool?
The command that I have been using with the proj binary is:
proj +proj=healpix -f '%.'17'f' +lon_0=0 +a=1 -E
0 0
EOF
I'm not sure what sourcePJ should be in the following example
[code]
         PJ sourcePJ = new PJ("+a=1 +lon_0=0");
         PJ targetPJ = new PJ("+proj=healpix");
         double[] coordinates = {
             0,       0,
         sourcePJ.transform(targetPJ, 2, coordinates, 0, 1);
         System.out.println(Arrays.toString(coordinates));
[/code]
Thanks
On 23/11/11 14:57, Michael Speth wrote:
> Anyone have experience with using the jniwrap java wrapper?
> I've compiled the jar and set the native library path; however, I get
> an error when I try to run the example from the README.  Is there
> something that I haven't configured correctly?
> [code]
>         PJ sourcePJ = new PJ("+init=epsg:32632");           // (x,y)
> axis order
>         PJ targetPJ = new PJ("+proj=latlong +datum=WGS84"); // (λ,φ)
> axis order
>             500000,       0,   // First coordinate
>             400000,  100000,   // Second coordinate
>             600000, -100000    // Third coordinate
>         sourcePJ.transform(targetPJ, 2, coordinates, 0, 3);
> [output]
> Exception in thread "main" java.lang.IllegalArgumentException:
> +init=epsg:32632
>     at org.proj4.PJ.<init>(Unknown Source)
>     at
> org.landcare.scenzgrid.proj4.test.HEALPixTest.main(HEALPixTest.java:36)
> Thanks
> Michael Speth
> Research Systems Developer
> Landcare Research
Michael Speth
Landcare Research
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111124/282764e9/attachment.html>
More information about the Proj
