[Proj] proj.4 problems
Frank Willett
fyw at wwwtools.com
Fri Nov 25 19:41:58 PST 2011
Hi All,
I have been testing proj.4 version 4.7.0 and have a few problems. I thought
I would submit them to the mailing list first for comments before submitting
them as bugs. Please let me know if you have a solution to any of these that
do not require modifying the source code.
For the problems at the origin, I ran the problem at 0,0 and 1,1 which is one
unit offset in X and Y.
aitoff - aitoff projection says it has an inverse but it doesn't.
Modified pj_aitoff.c to set no inv.
alsk - Compute LL from XY is wrong at the origin long/lat (-152,64)
$ proj +proj=alsk -I
>0 0
56dE 64dN
>1 1
151d59'59.926"W 64d0'0.032"N
gs48 - 1) The origin of the projection is at long/lat -96,-39 and it should
be at -96,+39
Modified pj_mod_ster.c to change the sign on phi0 for the gs48 projection
2) Origin problem
$ proj +proj=gs48 -I
>0 0
168dE 39dN
>1 1
95d59'59.958"W 39d11'17.79"N
gs50 - Origin problem
$ proj +proj=gs50 -I
>0 0
120dE 45dN
>1 1
119d59'59.954"W 45d0'0.033"N
imw_p - Origin problem
$ proj +proj=imw_p +lat_1=2 +lat_2=6 +lon_1=0 -I
>0 0
-2147483648d-2147483648'nan"E -2147483648d-2147483648'nan"N
>1 1
0d0'0.032"E 2d0'0.033"N
lee_os - 1) Got an email that the value of A is wrong
Changed from -0.0088162 to -0.00881625 (more accuracy)
2) Origin problem
$ proj +proj=lee_os -I
>0 0
30dE 10dS
>1 1
164d59'59.954"W 10d3'57.623"S
mil_os - Origin problem.
$ proj +proj=mil_os -I
>0 0
40dE 18dN
>1 1
20d0'0.037"E 18d6'48.274"N
pconic - Origin problem.
$ proj +proj=pconic +lat_1=0 +lat_2=10
>0 0
0.00 555891.27
$ proj +proj=pconic +lat_1=0 +lat_2=10 -I
>0 0
0dE 0dS
>0 555891.27
0dE 5dN
putp3p - Has the no inv. flag set but the inverse does exist
Removed the no inv. flag from putp3p .. inverse seems to work
tissot - Origin problem
$ proj +proj=tissot +lat_1=0 +lat_2=10
>0 0
0.00 -139902.82
$ proj +proj=tissot +lat_1=0 +lat_2=10 -I
>0 0
0dE 1d15'24.366"N
>0 -139902.82
0dE 0dN
wintri - wintri projection says it has an inverse but it doesn't.
Frank Willett (fyw at wwwtools.com)
More information about the Proj
