[Proj] Novice Examples?
Michael Speth
spethm at landcareresearch.co.nz
Thu Oct 6 16:04:30 PDT 2011
Thank you Frank for helping me with the initial parameters for testing
Spheroids! I am now trying to test Ellipsoidals and I have a problem
with the parameters I am passing proj.4.
Here are the arguments that I am trying to use:
./proj +proj=cea +lon_0=0 +e=0.5 +R_A=1 +ellps=WGS84 -E <<EOF
0 0
EOF
And the resulting output:
Rel. 4.7.1, 23 September 2009
<lt-proj>:
projection initialization failure
cause: invalid boolean param argument
program abnormally terminated
Anyone know what I've done incorrectly?
Thank you for your help.
On 05/10/11 12:25, Frank Warmerdam wrote:
> On Tue, Oct 4, 2011 at 4:05 PM, Michael Speth
> <spethm at landcareresearch.co.nz> wrote:
>> Greetings,
>> I am a new proj.4 user and I would like to try some simple examples.
>> I have been reading the user doc as well as the update (proj.4.3.pdf);
>> however, I have been unsuccessful with executing the examples listed.
>> ---- [ System Information] ----
>> System: Ubuntu 11.04 64-bit
>> Kernel: 2.6.38-11-generic
>> Proj.4 Version: 4.7.0 compiled from tarball
>> Here are two examples that show my problem:
>> ---- [Example 1] ----
>> /opt/proj-4.7.0/src$ ./proj +proj=poly +lon_0=-66 +lat_0=40 -v
>> <lt-proj>:
>> cause: major axis or radius = 0 or not given
>> ---- [Example 2] -----
>> /opt/proj-4.7.0/src$ ./proj +proj=poly +lon_0=-60 -E<<EOF
>> > # sample points
>> > 65W 43d15N
>> > -55 37.33
>> > EOF
>> <lt-proj>:
>> It seems that I am not providing the radius or major axis. Is this
>> correct, if so, how do I provide this information?
> Michael,
> You can specify the earth model several ways, but adding +ellps=WGS84
> is a fairly simple way.
> eg.
> ./proj +proj=poly +lon_0=-60 +ellps=WGS84 -E<<EOF
> Note that PROJ usually picks up the default ellipsoid from an initialization
> file but that doesn't work if you are running proj locally instead of first
> installing it. The main thing fetched from the defaults initialization file
> is a default ellipsoid.
> Best regards,
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111007/4fc80433/attachment.html>
More information about the Proj
