[Proj] Projection Dev - How to call other projections from a projection?
Michael Speth
spethm at landcareresearch.co.nz
Sun Oct 9 14:06:54 PDT 2011
Greetings,
I am working on implementing a new projection and stumped on how to
call a projection from within a projection.
For example, the projection has both a spheroid and ellipsoid. The
function for determine the projection of the ellipsoid (both forward and
inverse) use their respective spheroid projections during calculation.
Unfortunately, I'm not sure if the ENTRY function can be used because
for the ellipsoid calculation, but the spheroid function is only an
intermediate step int the calculation and there exists additional
computations after the spheroid function is called.
Consider this example:
INVERSE(e_inverse);
lp = INVERSE(p_inverse);
lp.phi = auth_lat(...);
return lp;
Does this make sense? If so, is there any way of calling the inverse
function for sphere within the inverse function for ellipsoid?
Thank you for your help
Michael Speth
Landcare Research
Scientific Programmer
More information about the Proj
