[Proj] Projection Dev - How to call other projections fromaprojection?
Noel Zinn (cc) ndzinn at comcast.net
Sun Oct 9 17:27:33 PDT 2011
Thanks.  Please clarify what you mean by "implementing"?  You're looking for
the Proj.4 commands that will pull this off?  Or you're coding this as an
additional projection in your instance of Proj.4?  Or you are coding this
projection in some language other than Python independent of Proj.4 and
thought the members of this forum could offer some guidance.  Pardon me if
I've missed the obvious.  -Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
-----Original Message-----
Sent: Sunday, October 09, 2011 6:56 PM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Projection Dev - How to call other projections
fromaprojection?
I meant ellipsoid and sphere; I apologize for confusing those terms.
I am trying to implement the HEALPix projection from a python
implementation from one of our team members.  The python version has
methods for projecting onto an ellipsoid as well as a sphere.  The
python version's forward and inverse ellipsoid functions call the
forward and inverse sphere functions.
We will also be implementing a new projection called an rHEALPix which
is documented here:
http://code.scenzgrid.org/index.php/p/scenzgrid-py/source/tree/master/docs/scenzgrid_math.pdf
Thank you for your help!
On 10/10/11 12:43, Noel Zinn (cc) wrote:
> "Spheroid" and "ellipsoid" are synonyms for the same thing in geodesy and
> cartography.  See:
> http://en.wikipedia.org/wiki/Spheroid
> Do you mean that you have an ellipsoid and a sphere, maybe a conformal
> sphere intermediate between the ellipsoid and the plane?
> What "new" projection are you implementing?  Does it have a name or is it
> something you invented?  Is it conformal?
> From: Michael Speth
> Sent: Sunday, October 09, 2011 4:06 PM
> To: proj at lists.maptools.org
> Subject: [Proj] Projection Dev - How to call other projections from
> aprojection?
> Greetings,
>     I am working on implementing a new projection and stumped on how to
> call a projection from within a projection.
> For example, the projection has both a spheroid and ellipsoid.  The
> function for determine the projection of the ellipsoid (both forward and
> inverse) use their respective spheroid projections during calculation.
> Unfortunately, I'm not sure if the ENTRY function can be used because
> for the ellipsoid calculation, but the spheroid function is only an
> intermediate step int the calculation and there exists additional
> computations after the spheroid function is called.
> Consider this example:
> INVERSE(e_inverse);
>      lp = INVERSE(p_inverse);
>      lp.phi = auth_lat(...);
>      return lp;
> Does this make sense?  If so, is there any way of calling the inverse
> function for sphere within the inverse function for ellipsoid?
> Michael Speth
> Landcare Research
> Scientific Programmer
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Proj mailing list
