[Proj] general question about upgrading PROJ.4
Duffy, Garret
garret.duffy at nuigalway.ie
Thu Oct 13 06:50:05 PDT 2011
Hi Roger,
This is what is returned when I type the commands:
garret at linux-gky9:~> ldd /usr/bin/proj
linux-gate.so.1 => (0xffffe000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0xb7fdb000)
libm.so.6 => /lib/libm.so.6 (0xb7fb5000)
libc.so.6 => /lib/libc.so.6 (0xb7e72000)
/lib/ld-linux.so.2 (0xb8031000)
garret at linux-gky9:~> ll /usr/lib/libproj.so*
-rw-r--r-- 1 root root 230K 2011-08-18 12:43 /usr/lib/libproj.so.0.6.6
lrwxrwxrwx 1 root root 16 2011-10-06 09:54 /usr/lib/libproj.so.0 -> libproj.so.0.6.6
lrwxrwxrwx 1 root root 16 2011-10-06 09:54 /usr/lib/libproj.so -> libproj.so.0.6.6
garret at linux-gky9:~> rpm -ql libproj0-4.7.0-9.1
garret at linux-gky9:~> proj
Rel. 4.5.0, 22 Oct 2006
So, I think the same as you had.
I will try what you suggest, remove the SLE11 Geo repo and suse repos with suse version greater than 11 and add susefactory. So, should I just reinstall grass and proj with this new configuration?
The reason I added the suse repos with version greater than 11 was to get python 2.6... but I guess you can't do that...
I wonder can I upgrade to from 11.0 to 11.2 without doing a clean install?
Thanks again for your help.
Garret
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Roger Oberholtzer
Sent: 13-Oct-11 2:05 PM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] general question about upgrading PROJ.4
On Thu, 2011-10-13 at 12:18 +0100, Garret Duffy wrote:
> Hi,
> Thanks for the reply. When I run the command, I get:
> libproj0-4.7.0-9.1
> proj-4.7.0-9.1
> libproj-devel-4.7.0-9.1
So at least the 4.5 RPM is not installed.
How about these commands:
% ldd /usr/bin/proj
libproj.so.0 => /usr/lib/libproj.so.0 (0xb76d0000)
libm.so.6 => /lib/libm.so.6 (0xb766d000)
libc.so.6 => /lib/libc.so.6 (0xb750d000)
/lib/ld-linux.so.2 (0xb770f000)
% ll /usr/lib/libproj.so*
lrwxrwxrwx 1 root root 16 2011-03-28 13:07 /usr/lib/libproj.so -> libproj.so.0.6.6
lrwxrwxrwx 1 root root 16 2011-03-28 13:05 /usr/lib/libproj.so.0 -> libproj.so.0.6.6
-rw-r--r-- 1 root root 247676 2011-03-18 14:38 /usr/lib/libproj.so.0.6.6
% rpm -ql libproj0-4.7.0-9.1
What I want to see is that /usr/bin/proj is using the libs in the installed RPM. Yours may contain a lib ending with .0.6.6. What do you get for these?
> I have OpenSUSE 11.0 installed with repositories for 11.1 and 11.2
> added to
> YaST2
> I used SLE_11 because the list of OSs in the GEO repository are:
> Parent Directory -
> CentOS_5/ 10-Oct-2011 02:11 -
> RHEL_4/ 18-Aug-2011 13:59 -
> RHEL_5/ 10-Oct-2011 02:11 -
> SLES_9/ 07-Oct-2011 18:05 -
> SLE_10/ 07-Oct-2011 18:04 -
> SLE_11/ 10-Oct-2011 20:35 -
> openSUSE_11.2/ 10-Oct-2011 20:38 -
> openSUSE_11.3/ 10-Oct-2011 20:43 -
> openSUSE_11.4/ 10-Oct-2011 20:39 -
> openSUSE_Factory/ 10-Oct-2011 22:33 -
> openSUSE_Tumblewe
> I didn't see an entry for openSUSE 11.0 so I thought SLE_11 was it...
> is that where I went wrong?
I think perhaps. The problem is that 11.0 is no longer supported. I have
11.2 and am in the same boat.
I would try openSUSE_Factory/ and disable all the other ones. And not only in the Geo area. I cannot think of any package that is in the CentOS/RedHat/SLED repos that is not in an openSUSE repo. In fact, I wonder if any RPM from those repos have been installed. Those other repos are for users of those operating systems. openSUSE wants to provide a one-stop location for all distros. But that does not mean you can mix them on your system!
If the same version of an RPM is in openSUSE_11.4/ or earlier, I would use the one closest to 11.0. It minimizes the chance of other things needing to be changed.
> I don't use linux every day, I only use it for grass and proj so you
> probably see that I am not an expert user by any means...
> Thanks,
> Garret
> "Roger Oberholtzer" <roger at opq.se> wrote in message
> news:1318500905.9020.74.camel at acme.pacific...
> > On Thu, 2011-10-13 at 10:43 +0100, Garret Duffy wrote:
> >> Hi,
> >> I have installed PROJ.4 version 4.7.0-9.1 using OpenSUSE YaST2 with
> >> the
> >> Geo/SLE_11 Repository.
> > If you are using openSUSE, why are you taking things from the SLE_11
> > repository? Which version of openSUSE are you using?
> > What do you get for:
> > rpm -qa | grep proj
> >> Everything installs fine and according to YaST2, the correct
> >> version has just been installed.
> >> However, when I run /usr/bin/proj, I get the message that version
> >> 4.5 is still installed even though the new version is supposed to
> >> be installed to that location. I have the same issue with GDAL, I
> >> upgraded it but when I run gdalinfo --version, it states the old
> >> version is still installed.
> >> I'm hoping someone can help.
> >> Garret
> >> _______________________________________________
> >> Proj mailing list
> >> Proj at lists.maptools.org
> >> http://lists.maptools.org/mailman/listinfo/proj
> > Yours sincerely,
> > Roger Oberholtzer
> > OPQ Systems / Rambll RST
> > Office: Int +46 10-615 60 20
> > Mobile: Int +46 70-815 1696
> > roger.oberholtzer at ramboll.se
> > Rambll Sverige AB
> > Krukmakargatan 21
> > P.O. Box 17009
> > SE-104 62 Stockholm, Sweden
> > www.rambollrst.se
> > Proj mailing list
> MB5!.1PT*&@H````-24A$4@```!8````6" 8```#$M&P[````!F)+1T0`_P#_
> M`/^@O:>3````"7!(67,```L2```+$@'2W7[\````!W1)344'TPD"%3<BH.WN
> MD ```CA)1$%4>-KME3UH$V$8QW]W27.V:6.DQ11:))&"E")-$031H047X806
> MU$%$+JN#'Z6#>T?%4A%Q$*YS%P,Y* XE+FX.J8M0T%Q;8ZN-YFPNYI+<AT-*
> MVM*F6K2#X //\N=Y?[S/P_]]7L'S/ XC1 XI_CVP(,OR+O'U8$H1)52WPLSY
> MA<N)OW+C^:Z48N50)T]GB10+RGQ72OEC\%PX-6P[J ]&<PP.Q)B\YJ-3*JIS
> MX8/#&V"M(QEW7._%_8L?"1[K87$53"?$O4L>1Z6RJG4DE0.#M>!L',].)\ZN
> MAFVIE\55&IFW0MPX5R7@<U4M./O;<(&K&W$$,7VF3PJ?C/B;%FZ4JKQ\*X!C
> M)>3R]9E?@Z]\*R &PBU2$ "_#RZ<VBK0U^L)4*O5P#8!AF3K9F8_L!_/'<.Q
> MJ/VPZH<]>^K+]T@\U%HO<#VHE3X;"&("1 - KBA-H5K@>1Q([_*QYG^F=A[O
> M4?JZM[0W'\ Q5S+ B&S?,II"_4_O at C@%)'>#?4^&\1U)#_1%\&\SX\*2`Z5E
> M`Y@&9F3WM at Z@B8^CP"AP!X@"!H(8V_/E:<*C-&V]P_TG6G?H^2*L%\I07 at .W
> MNCG,-F@)U0U6_F0 at B".R-Y[9VP:>.T9I.?MN)1J.1:2&W"Y!>W<K$&MH51MR
> M7RM at Z@8P(GOCF:9+2&;"`(8P]4QV*8>>![,"5FTK\T7(KI7)K;P'4T\",9F)
> MS+Y+:,=8>*ALSB^.&*BW7C4`=. 5,+T=V #__T$.'?P3(N;@\5,A'B\`````
> (245.1*Y"8((`
> end
> MB5!.1PT*&@H````-24A$4@```!8````6" 8```#$M&P[````!&=!34$``+&.
> M?/M1DP```"!C2%)-``!Z)0``@(,``/G_``" Z0``=3 ``.I@```ZF ``%V^2
> M7\5&````!F)+1T0`_P#_`/^@O:>3````"7!(67,```L3```+$P$`FIP8```$
> MR$E$050XRYV4:6Q4513'__>]-Z_S9CHS+6VG"Z5I*66 at 34HIH0(I*!;+8ENB
> M5F65A"4:1(W$)7S2J!\PT1AB8F*,-E:)0 at 11,2RFH!5,D+!(K=24MA:FG<J4
> MMK.]-V^[QP_3`D$3*;^O]^:7_SWGW"/B7G!XE?R:K<U+-NSY<#2B.W0]>5UR
> MY^9P+3PZ<85-3N at 1?26U\^?5K7NVYH%E3:;H\_Y\Y%B'/],=[;S4T=?WPZX=
> M(","`-)="04)2E[ES.I5.YY9NG+YNO3<W-R>`1W62 QSJA<%SO^I=HUJ`_D0 MI
> S8_R&6/'ZG)[^LG%L&HL$_?B=#-9Q3J_)GU:[=4-^X>EM9><F,:U%B5X,1
> M>+B 03X%%WM,=NUJPI8H*X,YO%/(5OMOBIE#$0H6/3Y_6?/6YU8MKEP1CB?Y
> M9ZT'/HU>'^RO7[UFX\*:0'6,"U+O@ 91M^!VN'$I*",XS,!%)KE$.=^DS#B3
> MLPHI.70!`"11\3H6;MF]??N6#:\\4.XI$&4 at 9OE05O+T3ETGDF51[!HTD(@F
> MD24[<%5UX\IUAC$UU2!!%)A+3,L<LUPD. N+>;0S53U?H+9TVZ:U+S17>0K2 M9, D@
> #D98A"9H8D7 at GI\#!"NMN-8,*)<(*!<X H53XR",P4';"="E.F!P#(
> M`"!8:D2W=,WF2 DG( !)@T,F#I<K#<.J`--*'=P4<P)%37!+$!A3%.:<&8#H
> MS ``(5"_N6%JECO[]B9.S.#0J 6W+""J,Q '^+B4$T V`3$;7+5AVX H.1VR
> M4EHJ./W%`"#D^/V!606>#!H7,@!QG=#1K\-4;;A<,A+FN'1";!(HP<$U&Y9)
> M($ZHGDW"QL;<PO3LV34`($;C6KQZ\?*'9^8I;IT(5VYP7!XPD>,2X//*"*L"
> M$AJ at ZH"J`O$XH$: 9(Q#UP@>R41330QKZB(HF\;$B]TQ<ZCGEZ-"N+/]['=M
> M9]J3%A"*< S>L#&W6(8WTX&$Q6"//]TT`<,`+ .P3( X4%5LX.7'8GABJ88I
> M7 at 9&-G+RBN<@S5\FDJE98[J()74K&YE#E"2!P>,3$4NF4B:20"0!Q-5;B17&
> MT5BI87UM'-.R+7";H[L_BI9O+H5.G3RPUQCK/"$!P$!'^X_?ME^^N*FI:D%0
> MMY!MIVII<\"P`,L&; L at 3JB<RK$BH&%&M@';$C \8N/(Z:#Q^5?'3G>?W_<^
> M)?K:`$0E`#!'_ at I_?W#?%PWW5]08!@FF2>#$8-J :0.6!7AD8&DE84&1"44"
> MDDF&R[TQ?+3_U]#1PWM;X\&3+>!:-P`.`.+$B(V&0T/YY0\^5%3H]X,!%@1$
> M5""I`T4>H*D"J"DB."4@%C?P=5N?\=:>+]O;#^]YS1@^VPJR!N_X"K>H:'CI
> MQ=8S4?- at ET9'0T3[NXG.A8 at TDXB(R+(X_=9U at S;O.A3T%C?L!E,"`(3_W8Z2
> M;UKN4V^?//7)F3B=&^84UH at X3TG5I$W[CO<DYS6^<5QPES0!\$QJE^?->[)Y
> M^\>]T>Z_=9J at +Z31SG?;KF7-6OTF!.>,NTIY)TSV*"6/?M#2\M,(Z2;1H=.#
> MR<7KWSDN^4H;`:1/6G@[CIPY%?6OMEUX_KT3O?[*1UZ'J-Q;RG_'%EE:WMS[
> >I(SI=9.NY3C_`'?'9X.OGHHO`````$E%3D2N0F""
> end
> Proj mailing list
Yours sincerely,
Roger Oberholtzer
OPQ Systems / Ramböll RST
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
www.rambollrst.se
Proj mailing list
More information about the Proj
