[Proj] rHEALPix new parameters
Michael Speth
spethm at landcareresearch.co.nz
Thu Oct 13 18:22:23 PDT 2011
Greetings,
I've implemented the HEALPix projection and have now moved on to
implementing a new projection called rHEALPix. I have two questions
regarding this implementation.
* rHEALPix requires 2 new parameters (spole and npole). How do I
specify those parameters on the command line? (In the code I am using
the pr_param function.
* The rHEALPix projection uses the HEALPix projection. So is it
possible to create a header with corresponding c file that shares common
functions between the HEALPix and rHEALPix projections? If so, how
should I name the files?
Thanks
Michael Speth
Scientific Programmer
Landcare Research
More information about the Proj
