[Proj] Proj4js EPSG:4326 to EPSG:26786 (SP NAD27) 100+ feet Off
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 14 19:57:28 PDT 2011
On Fri, Oct 14, 2011 at 7:38 PM, Scott DeHainaut
<scottdehainaut at comcast.net> wrote:
> Greetings,
> I'm working on a web project and using Proj4js for the first time to project
> coordinates from Google Maps lat/lon WGS84 into Massachusetts Stateplane
> NAD27 feet. To test my process I'm using a surveyed point for which I have
> both lat/lon and MA SP NAD27 feet coordinates. The surveyed coordinates in
> SP are easting 866074.86 and northing 231916.59.
> When I use Proj4js to go from lat/lon to MA SP NAD27, I'm 100+ feet from the
> surveyed coordinates. Here's the javascript snippet that's performing the
> conversion:
> var latGeo = 41.63238400230
> var lonGeo = -70.52620887720
> var source = new Proj4js.Proj('EPSG:4326'); /* Lat/Lon projection */
> var dest = new Proj4js.Proj('EPSG:26786'); /* MA SP Mainland NAD27
> projection */
Scott,
I do not think that Proj4JS does datum shifts that
involve grid shift files (like NAD27 to WGS84).
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
More information about the Proj
