[Proj] rHEALPix new parameters
Frank Warmerdam
warmerdam at pobox.com
Sun Oct 16 15:55:06 PDT 2011
On Sun, Oct 16, 2011 at 3:27 PM, Michael Speth
<spethm at landcareresearch.co.nz> wrote:
> Thanks Frank!
> * New Parameters *
> For adding new parameters, what is the command line syntax?
> Example: proj -v +proj=rhealpix +lon_0=0 +a=1 +R_A +ellps=WGS84 npole=0
> spole=0 -E <<EOF 0 0 EOF
> This doesn't seem to work. I've also tried using +npole=0 and +spole=0 and
> also doesn't work. How do I fix this?
Michael,
I'm not sure. With the "+" prefix, they should be available for pj_params
calls. If you provide your code I could investigate.
> * On Combining 2 Projections into 1 File
> Typically, there are 2 to 4 Functions FORWARD(s_forward),
> INVERSE(s_forward), and etc. Would I need to create 8 of these functions (4
> for each projection)?
Yes, I imagine so.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
More information about the Proj
