[Proj] rHEALPix new parameters
Michael Speth
spethm at landcareresearch.co.nz
Mon Oct 17 19:00:02 PDT 2011
Thank you Frank!
I've added your recommended fixes and it works! We will now start
thoroughly testing. Do you have any suggestions for testing?
Thanks
On 17/10/11 16:19, Frank Warmerdam wrote:
> On Sun, Oct 16, 2011 at 7:18 PM, Michael Speth
> <spethm at landcareresearch.co.nz> wrote:
>> Hello. I updated the source to use the trunk. Here are the updated
>> changes.
>> http://code.scenzgrid.org/index.php/p/scenzgrid-proj4/source/tree/master/src/PJ_healpix.c
>> Thank you for looking over the source!
> Michael,
> Ah, you called my bluff! Debugging through the code
> I see the problem is (at least) that you did not specify a
> type code in the pj_param code. You need to prefix the
> parameter name with a type code character - 'i' for an
> integer parameter.
> eg.
> int npole = pj_param(P->ctx, P->params,"inpole").i;
> int spole = pj_param(P->ctx,P->params,"ispole").i;
> By the way, it is more conventional to collect such parameters
> in your initialization functions and to declare them as part of
> your projection details via the PROJ_PARMS__ macro. You can
> see an example of this early in PJ_gstmerc.c for instance.
> Best regards,
Michael Speth
Scientific Programmer
Landcare Research
More information about the Proj
