[Proj] Setting up a proj4 specification
Mikael Rittri
Mikael.Rittri at carmenta.com
Wed Oct 19 02:10:13 PDT 2011
Hello, Hanlie.
Jean-Claude is right that one needs to know the kind of projection,
but if we assume it is a Transverse Mercator projection, the projection
would be UTM zone 36N, so it is very likely that it is
"Arc 1960 / UTM zone 36N", EPSG:21096,
with area of use "Kenya and Uganda - north of equator and 30°E to 36°E".
As for the datum shift from Arc 1960 to WGS84, the EPSG gives four
possibilities, valid in Kenya and Tanzania, just Kenya, just Tanzania,
and Burundi, respectively. (Just go to http://www.epsg-registry.org/ ,
and query by filter with Name: "Arc 1960" and Type: Coordinate Transformation.)
Since Tanzania and Burundi is south of the equator, and since the
datum shift for Kenya and Tanzania is less accurate than the one
just for Kenya, you can probably use
+towgs84=-157,-2,-299
which is the datum shift "Arc 1960 to WGS 84 (2)", EPSG:1284,
Area of use: Kenya - onshore and offshore, accuracy 6 meters (one sigma).
This can probably be used in Uganda, too, but with worse accuracy.
I am not sure about the ellipsoid. EPSG gives seven(!) variants of
the Clarke 1880 ellipsoid, while the only predefined Clarke 1880
ellipsoid in Proj.4 is
clrk80 a=6378249.145 rf=293.4663 Clarke 1880 mod.
which agrees with your specification.
(According to EPSG, the ellipsoid for the Arc 1960 datum
is "Clarke 1880 (RGS)" with
semi-major axis = 6378249.145 m
inverse flattening = 293.465
The name agrees with your specification, but the inverse flattening
differs slightly. This might be an error in EPSG, and the difference
could be insignificant in practice.)
So, let's assume that clrk80 is correct. Then, you can try with
+proj=utm +zone=36 +ellps=clrk80 +units=m +towgs84=-157,-2,-299 +no_defs
Better datum shifts may be available from national authorities.
Best regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Jean-Claude Repetto
Sent: Wednesday, October 19, 2011 9:43 AM
To: PROJ.4 and general Projections Discussions
Cc: Hanlie Pretorius
Subject: Re: [Proj] Setting up a proj4 specification
Le 19/10/2011 09:03, Hanlie Pretorius a écrit :
> Hi,
> Can someone please tell me or point me to documentation that explains
> how to put the following information into a proj4 string for use in
> QGIS?
> Datum:
> D_Arc_1960
> Spheroid:
> Clarke_1880_RGS
> Semimajor Axis:
> 6378249.144999999600000000
> Semiminor Axis:
> 6356514.869549775500000000
> Inverse Flattening:
> 293.46630000
> False_Easting
> 500000.000000000000000000
> False_Northing
> Central_Meridian
> 33.000000000000000000
> Scale_Factor
> 0.999600000000000040
> Latitude_Of_Origin
> Thanks
> Hanlie
This information is not sufficient. It does not specify the projection.
It may be UTM, or Lambert Conformal Conic, or other ones.
The parameters of the datum transformation to WGS84 are also missing.
The documentation on the proj4 parameters can be found at http://trac.osgeo.org/proj/wiki/GenParms .
Jean-Claude
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
