[Proj] proj4 string for perfect sphere
support.mn at elisanet.fi
Sat Apr 21 03:14:20 PDT 2012
Bob Fischer [robert.p.fischer-1 at nasa.gov] kirjoitti:
> > Another trick is to project it to a single
> > standard projection which works all over the world and then
> > do the plane calculations if they are too hard to be done on the
> > sphere.
> Unfortunately, there is no such thing. Every projection has areas of
> the sphere where it fails miserably. Not just places of high distortion
> (eg, Mercator near the poles), but also places where points that are
> close to each other on the globe end up far apart on the projection (eg,
> Mercator at the International Date Line).
I meant more some projection which can be made to work all over the world
by first setting some initial parameters (for example transverse mercator
projection with some polar switches [axis swapping at poles]) to do some
detail work not to be forced to stay on the sphere (or ellipsoid). But this of
course limits your work to detail level only.
regards: Janne.
More information about the Proj
