[Proj] Gauss conformal Lo33 on Clarke 1880 Cape Datum to WGS84 UTM36S - NTv2 file needed.
Mikael Rittri
Mikael.Rittri at carmenta.com
Thu Aug 30 02:16:55 PDT 2012
Hello again Zoltan.
I wrote:
> As a last resort, if you have more examples of source and target points that are representative for your area of interest,
> one could use the SEVENPAR program from Killetsoft to compute a local 3-parameter or 7-parameter transform.
Actually, it is possible to use Proj.4 to compute a local 3-parameter transformation from
your single test point, but I have no idea how accurate it would be for the rest of your data.
By assuming the same height above the ellipsoids for your test point, I get the 3-parameter
transform
+towgs84=-144.47,-128.70,-288.68
which is tailor-made for your single test point, so:
> cs2cs +proj=tmerc +lon_0=33 +a=6378249.145 +b=6356514.966398753 +towgs84=-144.47,-128.70,-288.68 +to +init=epsg:32736
-49717.410 -2872274.540
450273.23 7128571.66 0.00
Best regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Mikael Rittri
Sent: Tuesday, August 28, 2012 4:20 PM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Gauss conformal Lo33 on Clarke 1880 Cape Datum to WGS84 UTM36S - NTv2 file needed.
Hello Zoltan,
[-- text deleted, see http://lists.maptools.org/pipermail/proj/2012-August/006408.html --]
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120830/d905c149/attachment.html>
More information about the Proj
