[Proj] cs2cs: Gauss-Krüger to WGS84
Jose Gonçalves jagoncal at gmail.com
Sun Dec 9 15:41:53 PST 2012
Hello
 cs2cs +init=/usr/local/share/proj/world:gk4-d +towgs84
> the result is
>  56d30'44.77"E  39d38'19.023"N 0.000
This use of cs2cs is not correct. You must run something like:
cs2cs *string_for_system_1* +to* string_for_system2*
The +towgs84=... is the part of a string that you use to give datum
parameters of that system
> That's far away. Another online example names:
>  cs2cs +init=epsg:31466 +to +init=epsg:4326
> which returns even worse:
>  32d6'20.91"E   46d39'54.638"N 16.676
The EPSG code 31466 is for GK zone 2. Your X coordinate is very large, so
it is more likely that the point is in a different zone, probably 4, which
has a false easting of 4500 km. In that case you get:
echo 4491957.175 5511210.407 | cs2cs +init=epsg:31468 +to +init=epsg:4326
11d53'13.028"E  49d44'14.871"N 48.659
At least this point is in Germany... The datum transformation parameters
used are the following:
+towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7
Regards
José Gonçalves
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20121209/fdd41685/attachment.html>
