[Proj] cs2cs: Gauss-Krüger to WGS84
Andre Joost
andre+joost at nurfuerspam.de
Sun Dec 9 21:12:10 PST 2012
Am 09.12.2012 23:57, schrieb Martin Trautmann:
> Hi all,
> may I ask for your help about how to use cs2cs.
> I got some sample data from southern Germany which (probably) comes in
> Gauß-Krüger format.
> A single sample point would be
> WGS84: 49.737475,11.88695
> GK: 4491957.175 5511210.407
> These values were computed by an online tool.
> When I try to convert from GK to WGS84, I guess I have to use:
> cs2cs +init=/usr/local/share/proj/world:gk4-d +towgs84
> the result is
> 56d30'44.77"E 39d38'19.023"N 0.000
> That's far away. Another online example names:
> cs2cs +init=epsg:31466 +to +init=epsg:4326
31466 is GK2, you should use EPSG:31468.
Correct syntax is
cs2cs +init=epsg:31468 +to +init=epsg:4326 in.txt >>out.txt
With in.txt containing the coordinates in Format East North
HTH,
André Joost
More information about the Proj
