[Proj] Hooijberg's algorithm needed
Mikael Rittri
Mikael.Rittri at carmenta.com
Sun Dec 30 02:23:04 PST 2012
In Snyder's book, "Map Projections: A Working Manual", the symbol k stands for the local scale factor, and you can find formulas for k for an ellipsoid-based LCC projection at the top of page 108.
http://pubs.er.usgs.gov/publication/pp1395
It may be possible to compute k with Proj.4, but I don't know how to do that.
Regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
28 dec 2012 kl. 20:44 skrev "Achim Hasenmueller" <achim.hasenmueller at gmail.com<mailto:achim.hasenmueller at gmail.com>>:
I'm interested in finding the relationship between scale factors of LCC maps
(aviation) that are designed so they can be put next to each other and therefore
have a different scale factor each.
The maps cover parts of Europe with standard parallels at 40°N and 52°N. The
scale factor differs slightly and I am interested in a formula to calculate it.
I have found this in a forum message from 2007:
"Find a chart that gives the true scale at 54ºN and divide that into 500,000.
This is the scale factor. For 51N the scale factor is 500/515=0.9709, = 1/1.03
Running Hooijberg's algorith for LCC, 2 parallels, the scale factor at
54N=0.97005."
Unfortunately a search for Hooijberg's algorithm was not successful. Any
pointers appreciated!
Thanks!
Achim
Proj mailing list
Proj at lists.maptools.org<mailto:Proj at lists.maptools.org>
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20121230/34a6edef/attachment.html>
More information about the Proj
