[Proj] PROJ: Further help with the swisstopo NTv2 grid shift ?
Sandro Santilli
strk at keybit.net
Wed Feb 1 05:15:41 PST 2012
On Wed, Feb 01, 2012 at 04:31:03AM -0800, Melita Kennedy wrote:
> One method would be to calculate the CH1903+ to WGS84 offset for each NTv2 grid point, concatenate them with the offsets from the original file and build a new NTv2 file. EPSG lists a 1m transformation from CH1903+ to WGS84, do a code search for 1676 at http://www.epsg-registry.org.
Great, sounds like what I did. Still unfinished. Will post for review
once completed.
> Disclaimer: I'm a member of the subcommittee that maintains the dataset.
Which dataset ? Swisstopo NTv2 or the epsg-registry ?
--strk;
,------o-.
| __/ | Thank you for PostGIS-2.0 Topology !
| / 2.0 | http://www.pledgebank.com/postgistopology
`-o------'
More information about the Proj
