[Proj] How grids work in PROJ4
Michal Seidl
michal.seidl at gmail.com
Tue Jan 10 15:49:07 PST 2012
Hello,
I moved forward on implementing quite new Czech projection called "Krovak
Modified" which is used in new ProjectedCRS EPSG:5224. I also want to
implement vertical datum "Bpv" by use of +geoidgrids but I found myself
lacking some basic information which I can not easily find on the web.
1) What kind of coordinate transformation is supported by PROJ 4.8.0?
- towgs84?
- nadgrids?
- geoidgrids?
- others?
2) Can I combined these transformation? And how they are applied? Look at
these situations:
cs2cs ... +proj=latlong +nadgrids=... +geoidgrids=... +towgs84=... +to
+towgs84 ... +geoidgrids=... +nadgrids=... +proj=latlong
What happens?
LLH->(dL,dL)->LLH->(dH)->LLH->XYZ->(3D)->XYZ(wgs84)->(3D)->XYZ->LLH->(dH)->LLH->(dL,dL)->LLH
I mean by this:
a) if there is +nadgrids and +towgs84 on the LEFT SIDE PROJ firstly changes
LL by dL,dL from grid before 3D transformation
b) if there is +geoidgrids on the LEFT SIDE PROJ thinks there is orthometric
height on input so firstly it changes H by dh from grid to get ellipsoid
height before 3D transformation
c) on the RIGHT SITE it should work in a opposite order. Firstly do 3D
transformation and than apply +nadgrids and +geoidgrids as there is
ellipsoid height on the imput from 3D transformation
I think PROJ should do this but I am not sure about it. I tried to do some
test but I got confused. Is there some document how it exactly works?
Thanks Michal
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-grids-work-in-PROJ4-tp7174312p7174312.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
