[Proj] How grids work in PROJ4
J. Luis
jmfluis at gmail.com
Sun Jan 15 12:12:07 PST 2012
On 15-01-2012 13:58, Thomas Knudsen wrote:
> 2012/1/14 Michal Seidl <michal.seidl at gmail.com
> <mailto:michal.seidl at gmail.com>>
> - Mikael Rittri explanation helps me a lot, I was really for a moment
> confused by Frank's one
> Mikael's clarification was, indeed, excellent and useful
> - Joaquim formula h = H-N is OK. But as Frank said +geoidgrids is only
> name and can be used for other height correction which is exactly my
> situation.
> But please note that Wikipedia and leading geodetic textbooks
> (Hoffmann-Wellenhof & Moritz: Physical Geodesy, as well as Torge:
> Geodesy) use a different notation:
> h: height above ellipsoid
> H: orthometric height (which to an excellent approximation is
> equivalent to the height above the geoid)
> Hence: h = N + H
> So following Joaquim's suggestion of +H and +h options is quite risky.
> Out of context you can never be sure what is meant by H and h.
> /Thomas
Ai, this is embarrassing for me. Off course I mistakenly swapped the H/h
as it never crossed my mind going against the notation followed by the
"Physical Geodesy" bibles.
Joaquim
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120115/582b38bc/attachment.html>
More information about the Proj
