[Proj] Trouble georeferencing data stored in a spherical projection.
Hermann Peifer peifer at gmx.eu
Wed Mar 7 06:05:16 PST 2012
On 06/03/2012 14:38, Mikael Rittri wrote:
> Of course, the problem is already solved in Proj.4, as the FAQ says,
> since we can use
> +nadgrids=@null
> for the first convention, and
Just to add that the FAQ is a bit outdated in this respect as in more
recent versions of PROJ, the so-called "strategic addition of
+nadgrids=@null to the spherical projection definition" isn't needed
anymore.
Hermann
$ echo 50 50 | cs2cs -v +proj=latlong +a=6378137 +to +proj=latlong
+datum=WGS84
# ---- From Coordinate System ----
#Lat/long (Geodetic alias)
# +proj=latlong +a=6378137
# ---- To Coordinate System ----
# +proj=latlong +datum=WGS84 +ellps=WGS84 +towgs84=0,0,0
50dE    50dN 0.000
$ echo 50 50 | cs2cs -v +proj=latlong +a=6378137 +towgs84=0,0,0 +to
# +proj=latlong +a=6378137 +towgs84=0,0,0
50dE    50d11'20.459"N 12575.088
