[Proj] PROJ 4.8.0 Release Candidate 1
Greg Troxel gdt at ir.bbn.com
Wed Mar 7 18:54:42 PST 2012
My experience trying to update pkgsrc with this:
* datumgrid 1.5 doesn't have a .tar.gz, only zip.
For no good reason, it's awkward in pkgsrc to have a package built from
distfiles with different prefixes.  So I'm using datumgrid 1.4 still.
Since that's not part of proj proper, it shouldn't affect 'make check'.
* test failure
Rel. 4.8.0, 6 March 2012
<cs2cs>: while processing file: <stdin>, line 4
pj_transform(): failed to load datum shift file
diff td_out with td_out.dist
18,25c18,25
< -5.5 52.0     *       * 0.000000000000
< -5.5000000000001 52.0000000000001     *       * 0.000000000000
< -5.4999 51.9999       *       * 0.000000000000
< -5.5001 52.0  *       * 0.000000000000
> -5.5 52.0     -5.501106465528 51.999890470284 0.000000000000
> -5.5000000000001 52.0000000000001     -5.501106465529 51.999890470284 0.000000000000
> -5.4999 51.9999       -5.501006458305 51.999790470257 0.000000000000
> -5.5001 52.0  -5.500100000000 52.000000000000 0.000000000000
> -5.5 52.0     -5.498893534472 52.000109529716 0.000000000000
> -5.5000000000001 52.0000000000001     -5.498893534472 52.000109529717 0.000000000000
> -5.4999 51.9999       -5.498793541695 52.000009529743 0.000000000000
PROBLEMS HAVE OCCURED
test file td_out saved
* missing files
not a problem, but please confirm that:
  nad2nad is no more
  nad_list.h and projects.h is withdrawn
Neither are listed in NEWS.  Also, the addition of proj.pc probably
merits inclusion in NEWS.
--- PLIST       2010-03-14 12:26:22.000000000 -0400
+++ A   2012-03-07 17:54:30.000000000 -0500
@@ -1,19 +1,16 @@
- at comment $NetBSD: PLIST,v 1.1.1.1 2010/03/14 16:26:22 wiz Exp $
+ at comment $NetBSD$
 bin/cs2cs
 bin/geod
 bin/invgeod
 bin/invproj
 bin/nad2bin
-bin/nad2nad
 bin/proj
-include/nad_list.h
 include/org_proj4_Projections.h
 include/proj_api.h
-include/projects.h
 lib/libproj.la
+lib/pkgconfig/proj.pc
 man/man1/cs2cs.1
 man/man1/geod.1
-man/man1/nad2nad.1
 man/man1/proj.1
 man/man3/pj_init.3
 share/proj/FL
* postgis
I built postgis (svn trunk) against an installed proj-4.8.0 package
(built and packaged from the RC1 tarball).  It built fine, and passed
regression tests.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120307/5158ed2a/attachment.sig>
