[Proj] PROJ 4.8.0 Release Candidate 1
Greg Troxel gdt at ir.bbn.com
Fri Mar 9 18:01:10 PST 2012
Thanks for the datumgrid version explanation.
I got proj-datumgrid-1.5 and with that the test suite passes.
Would it be possible to get proj-datumgrid-1.5.tar.gz on the download
server?  That seems to be the only file available in zip but not .tar.gz.
Also, proj-datumgrid-1.5 lacks a clear license.  Are all of those files
public domain?
The README does not explain that proj-datumgrid-1.5 is needed; patch:
--- README.~1~	2010-12-05 11:06:32.000000000 -0500
+++ README	2012-03-09 20:55:09.000000000 -0500
@@ -40,6 +40,13 @@
 The install target will create, if necessary, all required sub-directories.
+To test, execute:
+	make check
+Note that you must have installed proj-datumgrid-1.5 in nad prior to
+building; the test suite includes grid shift tests.
 Windows Build
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20120309/bd41e122/attachment.sig>
