[Proj] Problems with /Op option used to compile proj in Microsoft Visual Studio
Charles Karney
charles.karney at sri.com
Tue Mar 20 14:32:48 PDT 2012
On 03/20/12 13:09, Calogero Mauceri wrote:
> Glynn, thank you very much for your explanation. So the smaller is the
> distance between the two points of the tpeqd, then the less accurate are
> the conversions. Those are really bad news:(.
In the limit where the distance between the two central points AB
vanishes tpeqd degenerates to the azimuthal equidistant projection (the
spherical variety because tpeqd is only implemented for a sphere). So
if you're projecting a point C and CA >> AB and CB >> AB, you might get
more accurate results using aeqd.
--Charles
More information about the Proj
