[Proj] [patch] add missing projects.h
Sisyphus
sisyphus1 at optusnet.com.au
Mon Mar 26 17:01:17 PDT 2012
----- Original Message -----
To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Cc: "Mark Brand" <mabrand at mabrand.nl>
Sent: Monday, March 26, 2012 9:35 PM
Subject: Re: [Proj] [patch] add missing projects.h
> On 26 March 2012 11:18, Greg Troxel <gdt at ir.bbn.com> wrote:
>> I had the impression that not installing projects.h was a conscious
>> choice in 4.8.0. So perhaps it belongs in noinst_include_HEADERS, but
>> your patch seems to revert the planned withdrawal, as noted in NEWS.
> Indeed, projects.h is a private header, not part of public API.
Oh ... so I guess our programs should no longer begin with:
#include <projects.h>
But if we delete that inclusion, will the programs still build ok against
4.7.0 and earlier ?
I recently updated from 4.7.0 to 4.8.0 and found a program (that began by
including projects.h) no longer built - the build failed with an error about
the unknown projCtx_t type. The projCtx_t type is defined in the 4.8.0
projects.h, but not the 4.7.0 projects.h (which was the projects.h that got
loaded).
Naturally, I fixed the error by replacing that 4.7.0 projects.h with a copy
of the projects.h from the 4.8.0 source :-))
(I did wonder why 'make install' had not done that for me .... )
This particular program will likely be built in various places by various
people using different versions of the proj library, so the code needs to be
portable.
Cheers,
Rob
More information about the Proj
