[Proj] DHDN / Gauss Krueger to WGS84
Roger Oberholtzer
roger at opq.se
Fri Mar 30 03:23:03 PDT 2012
Bad form to reply to my own post, but...
> > I would add that epsg:31467 expands as:
> > +proj=tmerc +lat_0=0 +lon_0=9 +k=1.000000 +x_0=3500000 +y_0=0 +ellps=bessel
> > +datum=potsdam +units=m +no_defs
> > it seems to work. A reference point of:
> > x = 4459750 m y = 5448182 m
> > is converted to
> > E11.446588 N49.169494
> If I use pj_transform(), I get:
> 21.982946, 48.433278
I see that cs2cs gives the same incorrect result I get, and not the
expected result:
cs2cs +init=epsg:31467 +to +init=epsg:4326
4459750 5448182
21d58'58.607"E 48d25'59.803"N -15.126
Yours sincerely,
Roger Oberholtzer
OPQ Systems / Ramböll RST
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
roger.oberholtzer at ramboll.se
________________________________________
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
www.rambollrst.se
More information about the Proj
