[Proj] DHDN / Gauss Krueger to WGS84
Roger Oberholtzer
roger at opq.se
Fri Mar 30 06:37:35 PDT 2012
On Fri, 2012-03-30 at 12:32 +0000, Mikael Rittri wrote:
> Hermann,
> you are right, of course.
After further investigation, I have found that the epsg:31468 in proj is
incorrect.
The proper (meaning it works for coordinates used by BASt, which is my
requirement) definition should be (Zone 4):
+proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel +towgs84=582,105,414,1.04,0.35,-3.08,8.3 +units=m +no_defs
The definition of +datum=potsdam as
+ellps=bessel +towgs84=606.0,23.0,413.0
seems to be the core problem. When I changed that to what is shown
above, I get reasonable values for my test data.
Ignore the fact that my original post had +x_0=3500000 and +lon_0=9.0
instead of +x_0=4500000 and +lon_0=12. I had been trying many
combinations and only posted the most recent. It was only the change to
+towgs94 that made any difference.
Here is another mystery:
I updated my epsg file to my preferred definition. Then, when I use
+init=epgs:13468 in the C API, I get locations that are 10 meters or so
away from when I specify the same values 'by hand' in the C API. My
entry in the file is:
<31468> +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel +towgs84=582,105,414,1.04,0.35,-3.08,8.3 +units=m +no_defs <>
Curious, no?
Yours sincerely,
Roger Oberholtzer
OPQ Systems / Ramböll RST
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
roger.oberholtzer at ramboll.se
________________________________________
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
www.rambollrst.se
More information about the Proj
