[Proj] Inconsistencies in projection definition (epsg 3857)
Jon Olav Skoien jon.skoien at jrc.ec.europa.eu
Fri May 4 06:59:39 PDT 2012
Dear list,
First of all, I am sorry if this is not the right list for the following
question.
We are working with some data that has been transformed from latlong via
different software and have encountered some inconsistencies with the
coordination system definitions of epsg:3857 (WGS 84 / Pseudo-Mercator,
often referred to as web mercator as it is used in web services such as
Google Maps). Some software (e.g. psql2shape) seems to use the
definition from spatialreference.org:
http://spatialreference.org/ref/sr-org/6864/
which gives the proj4 definition as:
+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
+towgs84=0,0,0,0,0,0,0 +units=m +no_defs
ogr2ogr appears to use a proj4 definition that is quite similar (gives a
dislocation of 10-20 meters in y-direction for some locations we have
checked)
+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs
+ellps=WGS84 +towgs84=0,0,0
However, the epsg-source of proj seems to use the following definition:
+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +units=m +nadgrids=@null +wktext  +no_defs
The difference for a random location in Europe is about 30 km in
y-direction between the two definitions (using e.g. cs2cs). Which
definition should we trust?
Thanks,
Jon
Jon Olav Skøien
Joint Research Centre - European Commission
Institute for Environment and Sustainability (IES)
Land Resource Management Unit
Via Fermi 2749, TP 440,  I-21027 Ispra (VA), ITALY
Tel:  +39 0332 789206
Disclaimer: Views expressed in this email are those of the individual and do not necessarily represent official views of the European Commission.
