[Proj] Proj4-API - pj_init_plus returns a NULL pointer for my ESRI projection string
Mikael Rittri
Mikael.Rittri at carmenta.com
Sat May 12 14:55:14 PDT 2012
PS:
Perhaps I was a bit unclear. I meant that if you replace "esri" by "epsg" in your initialization, then it should work.
Regards,
Mikael
12 maj 2012 kl. 19:18 skrev "Mikael Rittri" <Mikael.Rittri at carmenta.com>:
> Apparently, the Proj definitions have been fixed to use somerc, but not the corresponding Esri definitions.
> 11 maj 2012 kl. 09:53 skrev "Markus Eberhard" <markus.eberhard at InUnum.li>:
>> ( text deleted )
More information about the Proj
