[Proj] PROJ.4: pj_transform parameters
Doanh Hoang
doanh.hoang at mud-maps.com
Thu Oct 4 09:10:43 PDT 2012
Hi all
Im developer and this is the first time I touch PROJ.4 . And I have
following problem , please anyone can give me an advice:
In my project I need to do *transformation from datums (US, North America,
UK, South Africa, New Zealand) to WGS84. *
After having a look at defintion of pj_transform (function to do datums
transformation on PROJ.4). I have seen that there are so many input
parameters.
For example : following code that I found in internet :
projPJ src= pj_init_plus("+proj=tmerc +lat_0=38N +lon_0=128E
+ellps=bessel +x_0=400000 +y_0=600000 +k=0.9999
+towgs84=-146.43,507.89,681.46");
projPJ dst= pj_init_plus("+proj=latlong +datum=WGS84 +ellps=WGS84");
double x,y,z;
x=100;
y=100;
z=100;
pj_transform(src,dst,1,1,&x,&y,NULL);
params for initionlization of datums
+proj=merc +ellps=clrk66 +lat_ts=33 +proj=latlong +ellps=clrk66
There are so many geospatial knowledge neccessary to understand these
parameter.
Im developer and I know just only the simple name of datums(WGS84, NAD27,
NAD83, etc,..) and coordinates of points,
With them how I can make transformation between different datums ? *Where I
can get input parameters and define correct geospatial input parameters.*
I very need your help. Thanks a lot.
Hoang Doanh
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20121004/bea2125b/attachment.html>
More information about the Proj
