[Proj]  Azimuthal Equidistant question
    OvV_HN
    ovv at hetnet.nl
    Sun Sep 30 11:11:34 PDT 2012
In reply to:
Joseph White JWhite at terragotech.com
Fri Sep 28 08:33:59 EST 2012
Hi, all,
I'm trying to track down an issue I'm seeing with Azimuthal Equidistant
values when compared to ESRI.  The ESRI coordinate system I'm using is
World Azimuthal Equidistant.  I'm using some sample data that is in the
Tucson AZ area.
etc.
Reply:
Your values seem quite normal.
The values for the spherical azimuthal equidistant projection are
mathematically correct.
Are they really that far off?
The geonames.org server gives for Tucson Arizona the coordinates N 32° 13'
18'', W 110° 55' 35''
You cannot use the ellipsoidal azimuthal equidistant projection (in PROJ)
for distances greater than about 800 km from (lat0,lon0) or about 7.5
degrees.
Most ellipsoidal azeq projections are approximations, developed for areas
like Micronesia or Guam.
Oscar van Vlijmen
More information about the Proj
