[Proj] So close -- Lat / Long to Pennsylvania State Plane North NAD27
Jose Gonçalves
jagoncal at gmail.com
Thu Aug 8 08:20:57 PDT 2013
Jeremy
I think your installation of PROJ is OK. I get the same result with the
command line (I omitted some parts which are not needed):
echo -75.921819 41.295735 |cs2cs +proj=latlong +datum=NAD27 .... +to
+init=epsg:32028
2502332.66 416669.38 0.00
The problem is, I think, with the command line. The input system is
geographical coordinates in the Clarke 66 ellipsoid, so in the NAD27 datum.
The output is a LCC projection, also based on the NAD27 datum. There is no
datum transformation, so using +nadgrids is irrelevant. Your command is
doing only a map projection, that you could also do with proj command:
echo -75.921819 41.295735 | proj +init=epsg:32028
In your message you refer the NAD27 to WGS84 transformation, so it is
likely that your input coordinates are WGS84 geographical. In that case you
should use the command:
echo -75.921819 41.295735 | cs2cs +init=epsg:4326 +to +init=epsg:32028
2502234.97 416637.87 0.00
This result is much closer to what you were expecting (distance of less
than 1 metre).
> should return
> 2502235.76228 416637.89162
I hope this helps
Regards
José Gonçalves
2013/8/8 Jeremy Boecker <jeremy.boecker at gmail.com>
> Guys, I've tried everything suggested here in multiple variations, even to
> the point of rebuilding from the source code following the instructions in
> the FAQ, and I'm still getting the same output as is shown in my previous
> reply to this thread. I'm not sure what the difference is between what I'm
> doing and what Andre (one of the previous replies) is doing to be able to
> get the correct results. Would anyone be willing to give me a detailed
> step-by-step, starting with downloading "
> http://download.osgeo.org/proj/proj446_win32_bin.zip" and unzipping in a
> windows environment (I placed everything in C:\proj). See Andre's post
> above for the inputs and outputs. The second set of output coordinates is
> exactly what I need to get, but my output is just zeros and asterisks.
> Thanks so much folks for your help... I feel like I'm just missing
> something simple...!
> On Sun, Jul 28, 2013 at 6:03 PM, Mikael Rittri <Mikael.Rittri at carmenta.com
> > wrote:
>> I think you don't have the grid shift files that are required for
>> the Proj.4 default datum shift between NAD27 and WGS84.
>> The files are called alaska and conus, and NTv2.gsb for
>> Canada, and should be in the "nad" directory I think.
>> The US files can require an extra manual command to
>> generate, if you build Proj.4 yourself.
>> You can read more about this on the Proj.4 FAQ.
>> Best regards,
>> Mikael Rittri
>> Carmenta
>> Sweden
>> http://www.carmenta.com
>> 26 jul 2013 kl. 20:50 skrev "Jeremy Boecker" <jeremy.boecker at gmail.com>:
>> Thank you, I tried what you said, and what I'm getting as output is as
>> follows when I run the same batch file:
>> WGS84-NAD27
>> * * 0.000
>> WGS84-NAD27PAft
>> * * 0.000
>> NAD27-NAD27PAft
>> 2502332.66 416669.38 0.000
>> I'm thinking my EPSG definitions might be messed up somehow... but I
>> also tried copying from <http://spatialreference.org>spatialreference.org,
>> and still I get the same output. (It seems like the 4326 EPSG is not
>> working... ) Any further ideas? Your second result is the correct and
>> expected conversion result... not sure why I'm getting asterisks and zeros
>> for the same command! :/ Thanks again for your help!!
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
>> Proj mailing list
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130808/cba58151/attachment.html>
More information about the Proj
