[Proj] Proj4 Projection Coordinates for Geostationary satellitedata
Noel Zinn (cc) ndzinn at comcast.net
Tue Aug 13 07:43:45 PDT 2013
Your graphic shows the earth profile as an ellipse, but your proj4 string sets a and b to the semi-major axis of WGS84 (i.e. a sphere).  Why?  -Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
Sent: Tuesday, August 13, 2013 9:38 AM
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Proj4 Projection Coordinates for Geostationary satellitedata
Thanks Janne.
We did try drawing a limiting box inside the earth extents to get all valid data points within, and this works but cuts out data in the edges of the earth.  See the following image:
We still need the data in between the drawn dotted line blue box and the edge of the earth.  The data values in the red shaded off earth areas are very large (2.14 E9) and these are the values that throw the error.  If you do discard the values in the light red, that is fine but it is throwing an exception instead, preventing us from proceeding forward.
Thanks for the support!
On Tue, Aug 13, 2013 at 3:12 AM, <support.mn at elisanet.fi> wrote:
  Hello,
  we just discarded all points outside any reasonable area.
  Another possibility might be to draw a limiting line (or box)
  and move all outside points to that..
  Hope that helps?
  Regards: Janne.
  Kathryn Jablonski - NOAA Affiliate [kathryn.jablonski at noaa.gov] kirjoitti:
  > I am trying to convert geographic coordinates (in degrees east/north lat
  > lon) to projected coordinates in meters for geostationary full disc data
  > (GVAR Goes East data from CLASS).  To do this, I tried using PyProj/ Proj4
  > and am running into errors due to the off earth pixels in the corners.
  > This is the proj4 string given:
  >  projection_coords = Proj("+proj=geos +h=35774290 +a= 6378137 +b= 6378137
  > +lon_0=-75 +units=meters +no_defs")
  > ll_x, ll_y = projection_coords_geos( LL_y_deg, LL_x_deg, inverse = False,
  > errcheck=True)
  >     'x=%9.3f y=%11.3f' % (ll_x,ll_y)
  >     ur_x,ur_y = projection_coords_geos( UR_y_deg, UR_x_deg, inverse =
  > False, errcheck=True)
  >  'x=%9.3f y=%11.3f' % (ur_x,ur_y)
  > For full disc geos data I am receiving incorrect (1e30) values for the
  > extents and was wondering if anyone has ever run into the same error or
  > have a suggestion to correct this.
  > Also, for remapping GOES data, should the 'sweep axis' be including in the
  > Proj string and set to 'y'?
  > Thanks in advance for any suggestions!
  > Proj mailing list
  > Proj at lists.maptools.org
  > http://lists.maptools.org/mailman/listinfo/proj
  Proj mailing list
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130813/b19ec44b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130813/b19ec44b/attachment.png>
