[Proj] Misplaced SHP obtained with PROJ 4.8.0 called from gvSIG CE
Hermann Peifer
peifer at gmx.eu
Mon Aug 26 10:25:56 PDT 2013
On 2013-08-26 18:43, Jorge Arevalo wrote:
> Ok, so, if I didn't misunderstand:
> - These proj strings should be valid for epsg:23030 to epsg:25830
> transformation using mentioned grid file:
> source SRS: +proj=tmerc +lat_0=0.0 +lon_0=-3.0 +k=0.9996 +x_0=500000.0
> +y_0=0.0 +ellps=intl +units=m +nadgrids=@sped2et.gsb +no_defs
I never heard of the "@gridshiftfile.gsb" option. I only use
+nadgrids=gridshiftfile.gsb (if the file is where PROJ expects it to be,
on my MacBook at /opt/local/share/proj/) or
+nadgrids=/path/to/gridshiftfile.gsb
> destination SRS: +proj=tmerc +lat_0=0.0 +lon_0=-3.0 +k=0.9996
> +x_0=500000.0 +y_0=0.0 +ellps=GRS80 +units=m +nadgrids=@null +no_defs
> (not sure about the need of +no_defs part, but included just in case)
+no_defs is not needed in the above case.
> - These proj strings should be valid for the same transformation, but
> without using any grid file:
> +y_0=0.0 +ellps=intl +units=m +nadgrids=@ null +no_defs
If you have +nadgrids=@null on both sides (source and target SRS), then
no actual transformation will be made.
> And the important thing about the change PROJ.4 4.5.0 to PROJ.4 >=
> 4.6.0 is that PROJ.4 version >= 4.6.0 needs a datum specification for
> *both* source SRS and target SRS in order to "make the datum shift".
> So, in the case I don't have a datum specification by default, I
> should *always* add +nadgrids=@null or +toWGS84=0,0,0.
Hmm. Blindly adding +nadgrids=@null or +toWGS84=0,0,0 would actually
bring you back to PROJ 4.5.0 behaviour, and I doubt if you want this. At
the time, the PROJ developers had good reasons for changing the
behaviour of PROJ version >= 4.6.0.
However, in your example case the target datum is ETRS89 which is
practically identical with WGS84, so using +nadgrids=@null or
+toWGS84=0,0,0 is appropriate.
Hermann
More information about the Proj
