[Proj] NTv2 nested grid issues (Issue #177)
Chris Crook
ccrook at linz.govt.nz
Sun Dec 1 13:16:47 PST 2013
Hi
I've just struck the problem with NTv2 grids with nested subgrids of arbitrary depth. This was noted in issue #177 from 18 months ago, though I think the proposed fix there is not completely correct.
I've submitted a patch against this issue. Is there any chance this could be include in 4.9 please?
Thanks
Chris
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20131202/6e86cfcd/attachment.html>
More information about the Proj
