[Proj] Creating a nadgrid shift file
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Jan 21 03:36:23 PST 2013
Hi Jose, I can produce a working gsb file, but somehow the coordinate
range is wrong. It must have something to do with the way the base grids
are produced with gdal-grid. Could you give me an example of working
long/lat distance grids (surfer is OK), and the way you made them?
Jan
On 01/18/2013 11:51 AM, Jose Gonçalves wrote:
> Hello
> I have a program to create GSB files from two long/lat difference
> grids in Surfer format.
> http://www.fc.up.pt/pessoas/jagoncal/coordenadas/write_gsb.exe
> You can check with it. The longitude difference in the input grid are
> in the standard way (east positive).
> Regards
> José A. Gonçalves
> 2013/1/17 Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>>
>     (Sorry for crossposting, don't know if it is a gdal or proj problem )
>     This has been discussed on this list some time ago. I have been
>     able to create a working nadgrid file with gdal, but it doesn't
>     return the right coordinates. I did it as follows:
>     - create a 4 band, float32 geotif, each pixel with the
>     displacements in lat, lon (arcseconds), errorx and errory (both zero)
>     - gdal-translate it to ntv2-format.
>     The displacements in the geotiff are correct, and proj returns
>     shifted coordinates when using the ntv2-file, but not on the right
>     location. I'm really out of my wits. Could it have something to do
>     with ntv2 using negative lon-values east of Greenwich? Any help
>     would be appreciated.
>     Jan
>     _______________________________________________
>     Proj mailing list
>     Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
>     http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130121/3baffe86/attachment.html>
