[Proj] Italian Datum
Mikael Rittri
Mikael.Rittri at carmenta.com
Fri Jan 25 05:08:26 PST 2013
Hello Jan,
I would think it is EPSG:4806, "Monte Mario (Rome)".
If you use
+init=epsg:4806
this would expand to
+proj=longlat +ellps=intl +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68 +pm=rome +no_defs <>
(at least in Proj 4.8.0). The datum shift is intended for the
Italy mainland, and has accuracy 4 meters. There are other
published datum shifts designed for Sicily and Sardinia,
also with 4-meter accuracy, but if I recall correctly they
don't disagree by more than about 5 meters from the mainland
datum shift.
And there are several datum shifts for offshore areas
around Italy; I haven't compared them with the mainland
datum shift.
For a map in scale 1:100000, I think the mainland datum shift
should be okay for the entire Monte Mario area.
Off-topic: Since about Christmas, I only get a small random
subset of the Proj mails to my e-mail account. I don't
think it is due to my spam filter or wrong subscription
settings.
Am I the only one with this problem?
Best regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-------- Original Message ---------
Jan Hartmann j.l.h.hartmann at uva.nl
Fri Jan 25 06:49:24 EST 2013
________________________________________
Hi all,
I'm indexing an Italian map series 1:100.000, published around 1950 on
the basis of measurements in the first half of the 20th century. Map
sheets are registered in lat-lon values, 30 seconds east-west 20 seconds
north east, with Rome as central meridian (12d27'08''40). Those values
are on the International Ellipsoid. I would like to transform those
values to WGS84. In the Proj4 epsg file I find lots of latlon
projections with ellps=intl and different +towgs84 parameters. I read
Cliff Mugnier's column about Italy
(http://www.asprs.org/a/resources/grids/08-2005-italy.pdf), but I am
unable to find which epsg number is most appropriate for these maps. Can
anyone help?
Jan
More information about the Proj
