[Proj] Help with a custom projection that is Transverse Mercator with Affine post-process
Hermann Peifer peifer at gmx.eu
Tue Jan 29 05:54:24 PST 2013
About the meaning of the 6 parameters for the affine transformation, a
random Internet search gave me this definition:
The six values A, B, C, D, E, F have to satisfy this formula:
AX + BY + C = X'
DX + EY + F = Y'
testdrive.mapinfo.com/techsupp/miprod.nsf/kbase_by_product/0B57EA4620B5EBF285256A010082A16A
Hermann
On 2013-01-29 7:02, Mikael Rittri wrote:
> Hello James.
> Just a partial answer, I am afraid:
> I don’t think you can add an affine post-processing to a Proj.4 CRS
> definition.
> For your example, the interpretation of the MapInfo CoordSys clause
> should be
> “CoordSys Earth Projection”, // Just a name (probably the wrong one in
> this case)
> 8,                  // The projection type, in this case Transverse Mercator
> 33,                // The geodetic datum, in this case GRS80 (treat it
> like WGS84)
> 7,                  // length unit, in this case meter
> 117,               // central longitude
> 0,                  // central latitude
> 0.9996,          // scale factor
> 500000,         // false easting
> 10000000,      // false northing
> 7,                  // length unit for affine transformation, also meters,
> 0.890953, -0.455062, 2903977.24, 0.455063, 0.890954, -6919253.68,
> // affine parameters A, B, C, D, E, F
> -100000, -100000, 100000, 100000               // bounds
> I think the basic CRS in this example can be expressed in Proj.4 as
> +init=epsg:28350
> which gives GDA94 / MGA zone 50, but I think you must implement the
> affine transformation yourself.
> I got the information from
> http://www.sgsi.com/dnld/MapInfoPro_UserGuide_Current.pdf
> but I didn’t understand the meaning of the affine parameters.
> And I think the 8 ought to have been 3008, maybe…
> Best regards,
> Mikael Rittri
> Carmenta
> Sweden
> http://www.carmenta.com
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
