[Proj] Define custom proj4 CRS
Hermann Peifer
peifer at gmx.eu
Thu Jan 31 10:53:24 PST 2013
Dear both,
I just came to the same conclusion that EPSG:22523 would be the most
appropriate CRS. It's proj4 representation is:
+proj=utm +zone=23 +south +ellps=intl +towgs84=-206,172,-6,0,0,0,0
+units=m +no_defs
However, as Stephane mentioned: the units of IBGE's DGN files are in km,
so one has to define a custom CRS with these parameters (same as above
with the exception of +units=km)
+proj=utm +zone=23 +south +ellps=intl +towgs84=-206,172,-6,0,0,0,0 +units=km
Hope this helps, Hermann
On 2013-01-31 16:03, Jose Gonçalves wrote:
> Dear Stephane
> The projection is standard UTM, south hemisphere, zone 23 (central
> meridian -45 deg).
> Datum Corrego Alegre has two versions: "Corrego Alegre 1961" and
> "Corrego Alegre 1970-72". They are similiar, with differences of only a
> few meters. (The lat/long coordinates of the datum origin are not needed
> for the CRS definition).
> The EPSG file included in Quantum GIS has both datums but for the older
> one no parameters are considered for the transformation to WGS84. So you
> would better consider "Corrego Alegre 1970-72".
> So, the EPSG code for your CRS is 22523. You can chose that in Quantum GIS.
> If you need to transform your data to WGS84 and need better accuracy
> transformations, there are datum shift grids for datum Corrego Alegre.
> Have a look at:
> http://www.ibge.gov.br/home/geociencias/geodesia/param_transf/default_param_transf.shtm
> Regards
> José Gonçalves
> PS: The IBGE ftp site seems to be off.
> 2013/1/31 Stephane Goldstein <s.n.g at gmx.com <mailto:s.n.g at gmx.com>>
> Hello.
> I have a vectorized version of a map from the Ilhabela
> <http://www.openstreetmap.org/?lat=-23.845&lon=-45.343&zoom=11&layers=M>
> island in Brazil, dating from 1975.
> I could not find in QGIS the corresponding CRS, so I want to
> establish it based on the information that is in the PDF version of
> the map:
> Universal Transverse Mercator Projection
> Units are in kilometers, starting 10.000 km south of the equator
> (around de south pole), counting towards the north.
> and 500 km west from the 45º W meridian, couting towards the east.
> Horizontal Datum is Corrego Alegre with the Hayford 1924 ellipsoid
> and origins:
> Latitude19° 50' 14.91" S
> Longitude 48° 57' 41.98" W
> Vertical Datum is from Marégrafo de Imbituba, SC, but I don't really
> understand what are the parameters of the vertical datum that need
> to be taken in account.
> I would be really thankful if someone can help me to set a proj4 CRS
> to this map.
> PDF map can be downloaded here
> ftp://geoftp.ibge.gov.br/mapeamento_sistematico/topograficos/escala_50mil/pdf/sao_sebastiao27963.pdf
> Vector (DGN) here
> ftp://geoftp.ibge.gov.br/mapeamento_sistematico/topograficos/escala_50mil/vetor/sao_sebastiao27963/vetor/
> Proj mailing list
> Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
More information about the Proj
